03 Turbo has a skip
Old 01 Dec 2012, 05:07 pm
Default 03 Turbo has a skip
Hey guys. I have been visiting here for years for info. Finally decided to join. Great site.
I have a problem that reoccurs. A year and a half ago the 03 started skipping during idle. After a couple days it started skipping during idle and when accelerating. Finally sounded like it was going to shut off. Took it to my regular mechanic. He changed the cam position sensor and the crank position sensor. Cured the problem. Last week the same problem reoccured. It did throw the 0300 and 0301 codes. Trying to save a buck I went to the Chrysler dealership and picked up the cam and crank sensors and just changed both myself. No change except it's not throwing the code now.Just still skipping or a very rough idle whichever you want to call it. Is worse under A/C load. Is there anything else I need to do with the sensors. It looked like they just went in one way and should have cured the problem. Please help.
Thanks.
Old 01 Dec 2012, 07:12 pm
Default Re: 03 Turbo has a skip
You are getting a miss code. Have you changed the plugs & wires?
Old 02 Dec 2012, 09:11 pm
Forgot to disconnect negative battery cable. Did that, waited an hour and reconnected. PT is purring like a kitten.
Driving impressions: 05 Turbo-Lite and 06 Turbo High Output trooplewis General Turbo Discussions 31 25 Oct 2012 04:21 pm
Turbo stuffs Manifold srt4 stage 3 SMT6 Turbo t3t4 50 trims and more bobgt Classifieds: For Sale/Trade 1 10 May 2010 02:29 pm
'04 2.4 With a Skip, no codes? Hunter01 Tech & Performance Forum 7 02 Aug 2008 07:27 pm
Skip stage 1 and go directly to stage 2? oldfashionedgent Stage Turbo Kits 25 21 Jul 2008 05:21 pm
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
