PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/index.php)
-   General Turbo Discussions (http://www.ptcruiserlinks.com/forum/forumdisplay.php?f=18)
-   -   Code P1776 (http://www.ptcruiserlinks.com/forum/showthread.php?t=59293)
Kamisha18 10 Mar 2016 06:42 pm
Code P1776
I have a 2005 pt cruiser 2.4L turbo.I was driving and the check engine light popped on.Went to auto zone and came up with code P0700 and P1776.The car is in limp mode and won't go over 40mph.What could be the problem or fix?
CREWZIN 10 Mar 2016 08:26 pm
Re: Code P1776
Welcome to the forum.
P1776 Chrysler Solenoid Switch Valve Latched in LR Position ... (this is a transmission issue which may involve replacing the valve body and solenoid pack; on some models there is a TSB on this problem so be firm with your dealer / Chrysler).
P0700 The automatic transmission computer has a problem
Both indicate a transaxle/transmission problem which needs a better diagnostic tool to pinpoint exactly what has to be done.
Kamisha18 10 Mar 2016 08:35 pm
Re: Code P1776
Does the Tsb say that it's either the valve body or solenoid pack?Im a woman and just wanted to get a little info on what could be the problem before I let the shop fix it or maybe try to screw me over.
CREWZIN 10 Mar 2016 08:55 pm
Re: Code P1776
Here's the TSB....
MIL Illumination - DTC P1776 Solenoid Switch Valve Latched in LR Position
MODELS:
2004 (AN) Dakota
2004 - 2005 (CS) Pacifica
2003 - 2004 (JR) Sebring Convertible/Sebring Sedan/Stratus Sedan
2003 - 2004 (KJ) Liberty
2003 - 2004 (KJ) Cherokee (International Markets)
2002 - 2004 (LH) 300M/Concorde/Intrepid
2003 - 2004 (PL) Neon/SX 2.0
2003 - 2005 (PT) PT Cruiser
2003 - 2005 (RG) Chrysler Voyager (International Markets)
2003 - 2005 (RS) Town & Country/Voyager/Caravan
2003 - 2004 (TJ) Wrangler
NOTE: Refer to the following table for specific applications.
Model Engine Transmission
AN 3.7L 42RLE
CS 3.5L 41TE
JR 2.4L or 2.7L 41TE
KJ 3.7L 42RLE
LH 2.7L or 3.5L 42LE
PL 2.0L 41TE
PT 2.0L or 2.4L 41TE
NUMBER: 21-001-13
GROUP: Transmission and
Transfer Case
DATE: January 31, 2013
RS/RG 2.4L, 3.3L or 3.8L 41TE
TJ 4.0L 42RLE
DISCUSSION:
If the vehicle operator describes a MIL illumination and the technician finds DTC P1776
Solenoid Switch Valve Latched in LR Position is set, the DRBIIIŽ can be used to access
the event data screen and look at the “TRS Code” reading.
NOTE: The solenoid switch valve is located in the valve body and NOT in the
solenoid pack.
TRS Code Reads TR2
If the “TRS Code” displays “TR2” it is an indication that the manual valve was not fully in
the OD position at the time the DTC was set. Check the shifter cable adjustment and
adjust if necessary. Also check the shift control system for excessive friction and/or routing
issues.
TRS Code Reads OD
If the “TRS Code” displays “OD” then a sticky solenoid switch valve is the primary cause.
Perform the proper diagnosis for the valve body. Inspect for foreign material in the solenoid
switch valve and plugs.
POLICY:
Information
ptcruisersteve 10 Mar 2016 11:34 pm
Re: Code P1776
P1776 - Solenoid switch valve stuck in L/R position
Possible causes and solutions:
1. Torn sealing ring on OD accumulator piston due to poor machining of bore
Repair accumulator bore and replaced sealing rings
2. Possible shift cable adjustment or failed pressure switch
Check shift cable adjustment & solenoid pack build date.
3. Sticking solenoid switch valve
Free up stuck valves in valve body
4. Failed L/R pressure switch
Replace the solenoid pack
Kamisha18 11 Mar 2016 08:16 am
Re: Code P1776
I'm confused about the Tsb.😂 But I'm going to show the shop the possible causes
Kamisha18 11 Mar 2016 01:16 pm
Re: Code P1776
Thanks to the both of you for your help.I really appreciate it.I showed the shop the TSB and hopefully it get resolved today
Kamisha18 11 Mar 2016 04:21 pm
Re: Code P1776
I have another question.The mechanic said when he cranked the car up the reader thing said its in neutral but it was parked.What does the mean?
Sorry I don't know anything about cars just don't want anyone to try to get over on me.
chunky 23 Jan 2020 11:33 am
Re: Code P1776
Hi All, I also have a similar problem. I live in the UK and drive a manual 2005 PT cruiser 2.2 CRD diesel. The engine service light came on and so using a cheap OBD scanner I saw two errors they are P1775 and P1776. My question What is/are the part(s) that I need to buy. Where they are located on the engine/gear box (picture please). A link to the item(s) where I can buy it/them. Regards chunky!!!!
ptcruisersteve 23 Jan 2020 04:52 pm
Re: Code P1776
For reference - we don't have 2.2 CRD diesel engines on this forum.
I would first check your transmission oil level if you are getting P01775 code.
