Missing hose
  • 1 Post By rob302
Old 24 Jan 2018, 08:15 am
Default Missing hose
Hey guys...I could use some help. I noticed yesterday when under the hood that I appear to be missing a hose. There is a connector on the side of the air filter housing, but nothing connected to it. It looks to be about 1/2" in diameter. Can anyone show a picture of what should be there and where it goes? This is on my 2005 PT GT 2.4L HO Turbo. Many thanks in advance.
Old 24 Jan 2018, 11:41 am
rob302's Avatar
Default Re: Missing hose
that would be #4 here. it goes to the valve cover "make up air hose"
https://www.moparpartssource.com/a/C...2219238.html#4
on my non turbo, i just replaced the broken hose with a foot of vaccum line run in a circle like an upside down cursive 'e'. -cheap and prevented kinking
Old 24 Jan 2018, 12:43 pm
Does anyone know the function of this hose?
Old 24 Jan 2018, 02:05 pm
rob302's Avatar
Old 24 Jan 2018, 02:09 pm
rob302's Avatar
it redirects the oil vapor, moisture, and any fuel that evaporates from the oil back into the intake tract so it gets sucked the engine and burned. it helps with emissions(not exhaust emissions, just fumes your car gives off), it helps with you not occasionally smelling oil, it helps keep the engine bay clean. it prevents debris from entering the engine. it might add 0.000000000002 mpg and HP since oil vapor and fuel are both flammable.
some people add an oil catch can there, some people (kids/ricers) put a breather filter on the valve cover where the hose starts. i think the idea is that without the oil/fuel vapor going back in the intake, the inside of the intake stays cleaner. my opinion is that both of these ideas are stupid and a waste of time. i would just replace the hose.
capevape likes this.
Old 25 Jan 2018, 07:39 am
Thanks Rob
Old 25 Jan 2018, 07:47 am
rckstein's Avatar
Inside the air box, is there a small filter in place?
It's the make up filter and looks like this:
Old 25 Jan 2018, 11:27 pm
I will check tomorrow.
Old 25 Jan 2018, 11:29 pm
I have looked at so many parts diagrams and this part number looks like the best option - 04884289AE
Can anyone double check me on this? 2005 GT
I just want to be sure before I order the part.
Missing hose and check valve Bluedog0159 Tech & Performance Forum 5 15 Jan 2018 09:11 am
missing egr valve hose ipath1 Tech & Performance Forum 2 14 Jun 2016 10:49 am
Took apart my cruiser, now i'm missing a hose. What is this? ingram87 General PT Cruiser Discussions 9 20 May 2016 03:36 am
Turbo Coolant hose? Replacement/Hose Size PTTuber Tech & Performance Forum 9 07 Aug 2015 05:27 pm
Informed im missing a hose on air intake? invidious Tech & Performance Forum 5 06 Aug 2014 01:07 pm
