AC and idle situation
Like Tree6Likes
  #11 (permalink)
Old 26 Jan 2018, 03:22 am
Default Re: AC and idle situation
Originally Posted by capevape View Post
If the fan were failing, wouldn't I also be experiencing overheating issues? I have monitored the engine coolant temperature on several occasions and this is what I have seen.
While idling, the coolant temperature will climb up to around 207-208 degrees and then the radiator fan kicks on and the coolant temperature drops back down to around 195 degrees. Is that normal operation?
Non turbo Pt Cruisers have a two speed fan, lower speed for engine cooling and high speed for AC condensing. Low speed usually goes out first because it used all the time where the the high speed is used to cool Freon lowering the pressure in the AC condenser with the AC on or Defrost on.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
  #12 (permalink)
Old 26 Jan 2018, 10:18 am
I'm not having any issues on my non-turbo PT Cruiser
  #13 (permalink)
Old 26 Jan 2018, 11:57 am
Originally Posted by JoeX View Post
When the fan begins to fail it will run sometime.
Best to check it when the engine shakes with the AC on to see if it is running.
+1 ^^^^^^^
Agree with JoeX. Brushes can be just barely touching and maybe intermittent.
  #14 (permalink)
Old 26 Jan 2018, 04:00 pm
This is a video of me testing for bad motor mounts.. What do you guys think?
https://youtu.be/4lI4rmJ7ZtY
  #15 (permalink)
Old 26 Jan 2018, 04:05 pm
Originally Posted by ptcruisersteve View Post
+1 ^^^^^^^
Attachment 27540
I'm confused. The radiator fan is running when the AC is on. The car ALWAYS shakes when the AC is on. JoeX said that non-turbo Cruisers have a two speed fan. I posted this in the Turbo forum because it is about my Turbo Cruiser. Do the Turbos have a different fan? What should I be looking for?
  #16 (permalink)
Old 26 Jan 2018, 04:23 pm
Only the 2003 Turbo fan is different. It has a one speed variable fan and it is very expensive.
  #17 (permalink)
Old 26 Jan 2018, 04:26 pm
I think it has too much movement. I would check the upper and lower torque struts. The lower torque strut (dogbone) is usually the one that wears out first.
You should be able to crawl underneath with a flashlight and see if the rubber has tears in it.
  #18 (permalink)
Old 26 Jan 2018, 04:34 pm
I believe all forum post or reply's are shown when you or I click on NEW POST. Thats how we see New Post and reply's.
When starting a new post its always best to describe you PT
Thank you
73 Charger SE
01 Sebring flip
  #19 (permalink)
Old 26 Jan 2018, 04:36 pm
I would guess it jumps pretty good when you put it in drive or reverse.
73 Charger SE
01 Sebring flip
  #20 (permalink)
Old 26 Jan 2018, 04:42 pm
Thanks guys! I will crawl under and take a look at the rubber. Are there special mounts for the GT?
Crank no start situation 1986b2000 General PT Cruiser Discussions 4 08 Mar 2016 10:45 pm
Key Won't turn... different situation hivetyrant36 General PT Cruiser Discussions 2 19 Nov 2010 08:21 pm
oily situation... superpug666 Turbo Performance 2 24 Jul 2010 01:30 pm
Making the most of a Good situation TexasPriest General PT Cruiser Discussions 2 28 May 2009 01:20 pm
Someone explain the warranty situation! alexatanes General PT Cruiser Discussions 6 14 Nov 2008 10:39 pm
