Go Back   PT Cruiser Forum > Regional Forums > Midwest PT Forum
2001 PT Cruiser LE Boken Help
Old 19 May 2013, 02:12 pm
Unhappy 2001 PT Cruiser LE Boken Help
My son was driving my PT 2001 Automatic 2.4 and all the sudden it just stopped! I took it to the mechanic he said the timing belt needed replaced. Now he has called an said that the 3 Valve is bent, a 450.00 job went to 1300.00 to repair. I suggested finding a used engine he said that would be less expensive but then once he gave me the new quote it wasn't. 475.00 to put in the engine plus an additional 300.00 in labor to replace timing belt. I need to know where to begin to look for a new engine and what a good price is? Please help me!
Old 19 May 2013, 03:08 pm
Default Re: 2001 PT Cruiser LE Boken Help
Originally Posted by CruiserBrokensad View Post
My son was driving my PT 2001 5 speed Manual 2.4 and all the sudden it just stopped! I took it to the mechanic he said the timing belt needed replaced. Now he has called an said that the 3 Valve is bent, a 450.00 job went to 1300.00 to repair. I suggested finding a used engine he said that would be less expensive but then once he gave me the new quote it wasn't. 475.00 to put in the engine plus an additional 300.00 in labor to replace timing belt. I need to know where to begin to look for a new engine and what a good price is? Please help me!
I would suggest you check your local Craigslist site and look under the auto parts section. I know where I'm at in MI, I've seen a few engines on there and a full parts car or two. Best of luck.
Old 20 May 2013, 12:36 am
UptownSport's Avatar
How does he know #3 valve is bent?
Pulling the head isn't really that much harder after you have timing belt off-
need to remove a support to exhaust manifold, the cams and timing cover-
Valves are pretty cheap, IF it is indeed bent, which is unlikely.
2001 PT Cruiser Teckspeed General PT Cruiser Discussions 10 02 Jul 2011 08:44 pm
2001 PT Cruiser getting hot please help!!! jtsebastian Tech & Performance Forum 1 15 Dec 2010 06:13 am
2001 pt cruiser jdp01 Tech & Performance Forum 2 07 Jul 2009 07:53 pm
