Go Back   PT Cruiser Forum > Regional Forums > Midwest PT Forum
PT Cruisers of S.E. Michigan
Like Tree343Likes
  #851 (permalink)
Old 28 Mar 2020, 11:20 am
Bolero's Avatar
Default Re: PT Cruisers of S.E. Michigan
Originally Posted by My02RedRide View Post
The 1684 is pretty common and why it sets in memory is a mystery. Usually battery disconnected or instant momentary battery loss. The 0304 code is misfire plug#4. With mileage of last tune up unknown. I would 1st off do plugs and wires... I prefer NGK V-fire and GOOD wires. Anti-sieze and dielectric also applied. Check wires going into coil pack from main engine harness back at corner of cyl head. Also I like a good shock treatment of Chevron Techron Concentrate fuel treatment in about a 1/2 tank of gas.... big bottle worth dumped in to clean the intake lower tract and injectors. Battery disconnect for about 5 minutes to clear PCM memory of active codes.
New Plugs & Wires last July...Will try the Chevron Techron...thanks for advice...
Chuck
  #852 (permalink)
Old 28 Mar 2020, 11:52 am
Wink Re: PT Cruisers of S.E. Michigan
Paul knows what he is talking about, that is for sure .
  #853 (permalink)
Old 30 Mar 2020, 09:41 am
Bolero's Avatar
Passenger side Break light out...bought Bulbs and Chevron Techron thru Amazon Online...Cheap and Fast...
CRUZ likes this.
  #854 (permalink)
Old 30 Mar 2020, 12:05 pm
My02RedRide's Avatar
I would still pull the intake and remove the plugs and wires.. See what's going on in #4 cylinder. I have had plug failure more times that I wish with one manufacturer. Look at #4 plug for carbon tracking. If plug looks somewhat OK I would next pull the injector tree (since the intake is already off) and inspect #4 and then swap injectors around to see if misfire follows. Let us know what you find or don't..
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
  #855 (permalink)
Old 30 Mar 2020, 03:04 pm
Bolero's Avatar
OK it won't be right away but soon, going to do the Techron & Battery thing first then will let you know if Engine Light persist's...
  #856 (permalink)
Old 31 Mar 2020, 04:03 pm
Since the coil pack fires cylinder 1 and 4 same time (when #4 fires compression cycle, #1 is firing exhaust cycle - waste spark set up) that would pretty much rule out the coil pack. Again pull wire off #4 and inspect wire terminal and post on coil for carbon tract or loose fitting. Incomplete tight connection in time will burn the metal tip on the wire end. Also what you can do with the intake ON you can get your fingers to #4 injector and wiggle the injector wire connection and see if anything changes. #4 injector is at the end of the fuel rail line and any trash (rust) would end up at end potentially partially or plugging that injector.
rockandroller and CRUZ like this.
  #857 (permalink)
Old 06 Apr 2020, 08:33 pm
Smile Re: PT Cruisers of S.E. Michigan
Darrin, it was good talking to you today. I hope we are able to take that
ride down river. It would be fun meeting up with others
Doug
Until than, keep safe !
  #858 (permalink)
Old 13 Apr 2020, 02:54 pm
Question Re: PT Cruisers of S.E. Michigan
Are the Toledo PT Cruisers still around ?
  #859 (permalink)
Old 06 May 2020, 08:48 am
Not seen any posts from you all in a while... everyone doing ok and well?
  #860 (permalink)
Old 06 May 2020, 12:52 pm
Alive and well... just sitting on my a$$ doing nothing!
CRUZ likes this.
New from Michigan PT200 Welcome New PT Cruiser Members 9 27 Oct 2015 08:54 am
First Coast PT Cruisers 2013 Show - "Cruisers at the Landing" ramman PT Cruiser Events 0 12 Mar 2013 09:05 am
Hello from Michigan dewey68 Welcome New PT Cruiser Members 7 27 Apr 2012 03:41 pm
Michigan PT Cruisers? ucantcme General PT Cruiser Discussions 17 29 Jul 2010 02:41 pm
Calling all west Michigan cruisers adomeit Midwest PT Forum 2 13 Feb 2008 09:47 pm
