Go Back   PT Cruiser Forum > Regional Forums > Northwest PT Forum
Oil Pan replacement
Old 02 Nov 2011, 06:14 pm
Default Oil Pan replacement
Need some help explaining how to take off oil pan? I have removed all the bolts except the two under the transmission. How can I get the bolts out without taking out the transmission?
Thanks for the help
Old 02 Mar 2012, 09:07 pm
Eddie9195's Avatar
Default Re: Oil Pan replacement
I know this post is old, but did you ever get it figured out?
I removed an oil pan last week without any problems. You may have to remove the inspection plate piece that goes in between the engine and transmission.
Old 31 Mar 2012, 09:12 pm
Davey's Avatar
I am interested too. Dealer gave me a horrendous estimate to have mine done. Mine is just a small seep so I won’t bother with it, though it does bother me.
Old 01 Apr 2012, 02:14 pm
UptownSport's Avatar
I'll go with Eddie-
Factory used (anti) bending braces between transmission and engine.
You could hit up Chromenut for the engine section of the FSM-
I have '01 engine section, if I have enough bandwidth to send it.
ECU Replacement nvo2003 General PT Cruiser Discussions 13 14 Jun 2016 09:37 pm
Looking to buy replacement rim nacho_libre Classifieds: Want To Buy 4 03 Jun 2010 04:18 pm
PCM Replacement tomklevan Tech & Performance Forum 1 16 Apr 2010 09:56 am
Oil Pan replacement??? renee1958 Tech & Performance Forum 12 13 Jan 2009 04:54 pm
