Go Back   PT Cruiser Forum > General Forums > PT Cruiser News and Rumors > PT Cruiser Of The Month
2002 BASE JUSE DIES AT IDLE OR DRIVING
Like Tree12Likes
  #11 (permalink)
Old 16 Mar 2023, 11:58 pm
FeelthySanchez's Avatar
Default Re: 2002 BASE JUSE DIES AT IDLE OR DRIVING
Originally Posted by TwoCruisersOldGuy View Post
I actually never throw parts at the wall hoping they stick. This is a list of items I had planned to do all at the same time as part of an updating/restoration for it ......... I buy gas everywhere so that is not it. A few have said it must be the PCM but that is expensive so I am not going to go there yet. The problem is that it can be a million things.
Some of the above is good to hear but at this rate, it would be easier to remove both license plates & just insert another PT in-between.
Which brand(s) of liquid FI cleaners have been tried?
It's been a while, but reconditioned ECMs used to be around for $200-$400 exchange, plus a trip to the dealer to blast the PROM.
Edit - here they are & still very cheap in Raleigh, NC: https://carcomputerexchange.com/chry...e/prod_24.html
rockandroller likes this.
Orig owner: Patriot Blue 2001 LE 5-spd.
100% stock except for KYB front struts, K&N air filter & oversized oil drain plug.
Totalled her for the 3rd & final time on 03 Jan 2023, & the damn thing still got me home safely - somehow.
Odometer reads 328,337 miles & we were still wheezing-along on the 2nd engine, 4th gearbox, 3rd ECM, 6th radiator, 3rd rack & pinon.
  #12 (permalink)
Old 17 Mar 2023, 07:54 am
Did you replace fuel injectors or just clean them? Did your do a "repair" just before the problem started? I've learned to test injectors, specially new one, before installing. On my last purchase 5 out of 6 injectors didn't spray or didn't stop spraying.
  #13 (permalink)
Old 18 Mar 2023, 11:12 am
rockandroller's Avatar
Thumbs up Re: 2002 BASE JUSE DIES AT IDLE OR DRIVING
If never any codes thrown, I'd suspect the computer.
I got a rebuillt ECU from Myckee a couple of years ago, and it fixed all the issues I was having. (The car previously had a ECU replacement in it's first year or so - long before it came into my hands, and was running great for about seven years then started acting up!)
https://www.ebay.ca/str/myckeesecus
Since I had the Turbo Lite, I asked Myckee for the "stage 1" tune, and that extra 40 HP is PALPABLE
** Gas mileage down accordingly, but it's worth it ...
2004 'Turbo Lite'
  #14 (permalink)
Old 20 Mar 2023, 09:29 am
Angry Re: 2002 BASE JUSE DIES AT IDLE OR DRIVING
Cleaned tank when new pump/filter was installed. Checked all lines, new injectors, rail, etc. I have had five Cruisers, never had this problem before. Finally doing ambient air sensor, both oxygen sensors, different crankshaft position sensor, neutral safety switch as we speak. The car is much faster and much smoother otherwise. Never had one run this strong. Next would be key tumbler/ignition switch I guess. I think it is a ground/short. Thanks for all the tips.
  #15 (permalink)
Old 22 Mar 2023, 05:07 pm
OK, Just installed, front and rear oxygen sensors at catalytic converter, and a "new again" crankshaft position sensor and it is MUCH MUCH worse. I now think it is the wiring for the Crankshaft position sensor. If no suicide, will update; don't hold your breath. This will be the first car that ever beat me. Lol
  #16 (permalink)
Old 22 Mar 2023, 05:10 pm
Next is ROCK AND ROLLER advice
  #17 (permalink)
Old 23 Mar 2023, 01:39 pm
Difficult finding something you haven't tried. I built a smoke generator using a small paint pressure pot, torch, low air pressure supply and some mineral (baby) oil. Hooked it up to the intake and looked for puffs of smoke (leaks).
In my case, didn't fine any but knew "that wasn't it" and it didn't cost anything.
  #18 (permalink)
Old Yesterday, 11:46 am
ptprice's Avatar
SOOO BIG was experiencing similar symptoms. The resolve was replacing portions of the ignition switch. PROBLEM SOLVED!
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chromed Side Spears, Grills, Fuel Filler Door, Door Locks, Handles/guards , PRND3-1 Bezel, Tail Lights, 3/8" Belt Trim, 5 piece bumper trim. Cool Vanilla White shift ball, Leather tilt steering wheel, Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry. Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers. Back up Camera, 7" Monitor.
01 cruiser dies while driving. cdefn Tech & Performance Forum 3 28 Jul 2018 11:12 pm
06 PT Cruiser stalls and dies while driving CruisingCalifornia General PT Cruiser Discussions 4 29 Jul 2015 10:05 am
2001 PT dies while driving....please help DallasTint Tech & Performance Forum 2 04 Mar 2015 04:38 pm
Engine cuts out/dies...while driving ScottS Tech & Performance Forum 2 13 Mar 2013 07:37 am
2001 LE Cruiser dies while driving xebix Tech & Performance Forum 5 10 Apr 2012 10:48 pm
