2002 PT w/AM FM CD & FM no Sound
Old 13 Oct 2008, 09:19 am
Default 2002 PT w/AM FM CD & FM no Sound
My PT radio, factory, the FM just doesn't work anymore. For a while, it came on after 5 to 10 minutes of cooling down in the TX heat, AC, then it worked fine. Now, no FM whatever. Got AM, and CD, but FM, seek, ok, no Volume on FM. Anybody else ever had an FM die only? Looks like the easiest fix is to replace the radio, unless someone got an idea? Im open.
Old 13 Oct 2008, 02:03 pm
Default Re: 2002 PT w/AM FM CD & FM no Sound
This is going to sound goofy, but give it a try since it doesn't cost anything.
Try readjusting the stearing wheel angle. I was loosing the readout on the radio/CD - it would flicker on and off. I messed with the stearing wheel and it's been working fine since. Maybe this will work for your issue as well.
Old 17 Oct 2008, 09:35 am
Send a message via Yahoo to partyd
It is just the fm tunner inside the radio is very cloe to the back and hot part of the radiio
radio needs to be repair or replace,factory radios are not to expensive and easy to replace
Chrysler.Dodge 02-03-04 factory radio P56038589 An
Old 17 Oct 2008, 10:51 pm
yes, Ive decided to replace the radio. just wanted to make sure it wasnt a recall or a similar prob with others.
Old 19 Oct 2008, 07:10 pm
And I've got a radio for sale if you're interested.
Frank
Old 20 Oct 2008, 08:28 am
Duster's Avatar
Do yourself a favor and grab a head unit with a jack 1/8" input.
It's unbelievable how it can be useful.
Ok...not really unbelievable but it's certainly very useful.
Old 23 Feb 2010, 10:25 pm
I found your thread while trying to research if there have been any recalls on the CD and radio in my 2001 PT Cruiser. The CD option is to use a 10 disc player under my seat, or the single CD player in the dashoard. In my case, I suspect dirt or a malfunctioning mechanical tray in my dash board CD player. The radio only works first thing in the morning when it is very cold. Once I turn off the engine and restart, the radio will not play and you can hear the CD player grinding away trying to find a CD (none is in the tray). The CD player, of course, has an automatic interrupt of the radio, and I suspect it is triggering a false interrupt. The cold make it sluggish enough for the radio to come on first and turn off the CD player. My patience, however, has worn out and I'm ready to hit it with a sledge hammer. I found nothing so far on recalls.
Trying to explain "the sound"... blucrsr Wheels, Tires, Suspension 12 10 Aug 2005 07:31 am
Optimum sound question stirfry Sound and Security Forum 3 12 Apr 2004 09:49 pm
Strange fluttering/rattling sound!? gsharrock Turbo Performance 19 21 Aug 2003 09:46 am
Chirping sound while making right and left turns ptcignaboi Tech & Performance Forum 14 19 Apr 2003 09:30 pm
