Dimming lights
Old 21 Feb 2010, 01:18 pm
Default Dimming lights
Ok, it's been years since the last time I had a system, and the ole brain didnt retain much from those days
With that said, when I am playing my stereo with the volume up at a good level, I notice the headlights (and dash), dimming to the beat of the subs. Obviously, there's power drain in there. Question is, any harm with this? ( i do turn the stereo down a bit at night now.
What are my options, new battery and alternator? Like I said, been awhile, so forgive the (most likely) obvious questions and answers.
Old 31 Mar 2010, 01:15 pm
chris15's Avatar
Default Re: Dimming lights
Kind of an old post, but since no one responded-- the first thing I'd start with is what most call a 'hypergrounding' system, in which you run wires directly from the negative terminal of your battery to key points under the hood of the car.
If you do a quick search for 'hyperground', you should find some more information about it.
Doing this essentially makes all the grounds on the car TRUE grounds, and eliminates one factor of dimming lights. It worked perfectly for me, but it depends on how much power you're running.. but it's cheap enough and simple enough to do, and if it fixes your issue, it's a whole lot cheaper than a battery or alternator.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Dimming Interior Lights CMABCA General PT Cruiser Discussions 2 23 Dec 2009 01:05 pm
Dimming Dash Lights UnderEstimated Tech & Performance Forum 0 14 Jan 2009 11:19 am
Lights are still dimming justine311 Tech & Performance Forum 4 19 Apr 2006 01:47 pm
lights dimming hawkeye_1 General Turbo Discussions 11 22 Nov 2004 02:09 pm
dimming lights and braking rc51billy General PT Cruiser Discussions 24 26 Jan 2004 02:28 am
