Horn not working, Fuses not blown... 2008 pt cruiser LX
  #11 (permalink)
Old 03 Jul 2015, 04:25 am
LionPT's Avatar
Default Re: Horn not working, Fuses not blown... 2008 pt cruiser LX
Originally Posted by MilanDavid View Post
Just opened the door with the key and the horn went off. Again Smacked the fuse box and it went off.
That sounds like the alarm went off.
https://answers.yahoo.com/question/i...9203711AANWPam
  #12 (permalink)
Old 03 Jul 2015, 02:05 pm
Have a 2008 PT the horn comes on out of the blue. I give the fuse box a smack and it stops. I think it is a relay in the fuse box but I don't know which one. Any thoughts. I'm new to forums and don't know how to post a new post. (yes I have been living under a rock and don't know how.
I believe what you are saying is that you are smacking the TIPM under the hood on your 2008 PT Cruiser. Your horn control circuit to the solid state horn relay might be shorted to ground. The TIPM has a solid state relay for the horn.
1. Check terminal 65 in tipm for continuity to ground indicates:
A. Wiring harness shorted to ground.
B. Find the short and repair as necessary
  #13 (permalink)
Old 03 Jul 2015, 02:23 pm
I think you are on to something, ptcruizersteve. The fuse box (aka TIMP) seems loose / not tightly mounted. The harness connections, as it ties into the TIMP, could have a loose connection or like you say a module on the board could be the issue. I am disconnecting the horn in the inner wheel well just to get it to the shop. I will post the resolution when they figure it out.
Thanks for the input
  #14 (permalink)
Old 03 Jul 2015, 02:40 pm
I would suggest that if they recommend you replace the TIPM you might want to consider having your own TIPM repaired. There has been many posts on how new TIPM have been defective or not working correctly. Post back what the repair shop finds.
  #15 (permalink)
Old 13 Jul 2016, 06:27 pm
On second generation PT Cruisers there is a wiring harness that runs over a sharp metal bracket ( it may be part of the driver side motor mount) Not really sure what is in the harness but mine was very snug over the edge. I put a piece of rubber under the harness as insulation to try to avoid future problems.
You might want to examine yours.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Ciggy lighter & Power outlet not working -all fuses fine. swisstony10 Tech & Performance Forum 19 09 May 2016 02:59 pm
'02 DC, 71k miles, Radio and horn stopped working Bulwapo Sound and Security Forum 10 18 Apr 2014 08:42 pm
Clock and horn quit working Frink General PT Cruiser Discussions 16 02 Dec 2012 06:01 pm
on a 2007 pt cruiser is there more than one location for fuses and relays? 07ptcruzin Tech & Performance Forum 2 16 Jun 2009 06:49 am
2008 PT Cruiser beelsamin Canada PT Forum 0 22 Dec 2007 03:43 pm
