pioneer remote wire to amp wont work
  • 1 Post By Chromenut
Old 30 Mar 2014, 02:12 pm
Default pioneer remote wire to amp wont work
my remote line to the amp stopped working, and i need another wire to run the turn on line to. what is a good wire to run it off of? i dont want to have to manually turn it on and off because i dont want to run into the problem of my battery being drained because i forgot to switch it off.
Old 30 Mar 2014, 02:24 pm
randyincctx's Avatar
Lightbulb Re: pioneer remote wire to amp wont work
I would think the wire for main power to the head unit(key-on) would be my obvious 1st choice,but another option might be the 'hot' wire to one of the 'key-on' 12v outlets(front & rear),which if your amp is in the rear is real convenient to the 12v supply located in the cargo area(less wire to run).
With either of those suggestions your amp will power-up whenever the key is placed in the ON/START or ACC. positions.
Aka:~KILLER~
Old 30 Mar 2014, 02:30 pm
Default Re: pioneer remote wire to amp wont work
There is only 2 reasons I can think of right now cause I'm half awake, as to why it quit working. Either the port on the amp quit, or somehow the wire itself is getting shorted (bad searching) or came unplugged.
But to answer your question, just run a separate wire WITH AN INLINE FUSE to the cigarettes lighter under the cubbybhole. That way it only comes on with he cars accessories and goes off when he car is off.
Old 30 Mar 2014, 02:31 pm
i never thought of running it to the rear 12v. that would be perfect and only be a foot of wire max. thanks ill have to work on that on my day off now.
01 pt touring, 16 inch borbet fs wheels plasti dipped teal, pioneer 900w amp, mtx 12 inch sub, yellow fog lights and lenses, blacked out tail lights, road magnets, kybs, borla exhuast, freedom design strut bar
Old 30 Mar 2014, 02:42 pm
ok ill run a fuse with it. my old amp blew so its not the amp i just got a new one
Old 30 Mar 2014, 03:25 pm
Post Re: pioneer remote wire to amp wont work
Yeah...I forgot to mention the fuse(unually,but not always power wires have them already in-line),but that IS an important feature to protect both your car & amp.
And since the rear 12v outlet operates just like the Cig/12v,so it'll be OK as well.
Aka:~KILLER~
Old 30 Mar 2014, 03:51 pm
I have made this suggestion probably over 100 times - USE A RELAY, DON'T GO DIRECT TO YOUR IGNITION WIRING!
Amps/Head units draw a heavy load, and lots of times if you go direct to the power-on lead, it'll overload the wires and burn them out (I know this because it burned out mine!). Most stereos have a lead for on/off that is NOT the load lead. I highly suggest, and you do what you want, but suggest you link to a relay from the ignition/positive lead to the cigarette lighter.
There are two wiring diagrams I put together. This one is for fog lights, say you wanted to add them onto your car. However you can use this diagram for adding ANYTHING electrical to your PT. This one has a switch to control the on/off:
Now, if you would rather allow the car to control it, and lets say you want to be able to have your stereo come on when the ignition key is in the Accessory position, then try this diagram:
Both of these methods take any load off of your ignition switch and save your wiring. I highly suggest this to EVERYONE who wants to add something like a head unit, simply because if it's not OEM, then don't put your wiring at risk! Add to it, the relay is all of $8!!! It's actually quite simple to install and your stereo will work wonderfully.
j0e likes this.
Hard Wire Garage Door Remote njsteve1 Members PT Project 8 03 Jul 2014 04:40 pm
remote trunk opener don't work xtreme General PT Cruiser Discussions 2 08 Dec 2011 04:47 am
Amp remote wire Mulligandog Sound and Security Forum 11 16 Aug 2011 11:56 pm
Will this remote work? ProDigit General PT Cruiser Discussions 8 05 Jul 2011 06:39 pm
remote amp wire asnowboarder Sound and Security Forum 2 02 Mar 2008 12:18 am
