aftermarket radio in 06
Like Tree4Likes
  #11 (permalink)
Old 13 Apr 2015, 10:29 pm
rckstein's Avatar
Default Re: aftermarket radio in 06
Originally Posted by xwing777 View Post
That came out pretty good
If you don't mind, about how much did it cost you for the entire setup?
  #12 (permalink)
Old 13 Apr 2015, 10:54 pm
xwing777's Avatar
Theres 2 models of this same clarion head unit (both are called NX404 though) one with navigation thats around $400, one without navigation around $250 both on amazon. Great head units for the money. The wifes is a non navigation unit but I have the navigation model in my tundra.
The double din dash plate also on amazon was $99 and comes with all attachments needed. On the 2nd generation (like the 06' shown here) you only have to sand/grind the little ridges down inside the factory opening behind the face plate (will make sense once you remove the factory unit) and the radio sits in the snug pocket. Radio is very supported by the factory dash pocket and not the new face plate.
Check out the build thread i did on the wifes 06' (a lot of changes since i last updated it though)
http://www.ptcruiserlinks.com/forum/...reo-build.html
rckstein likes this.
  #13 (permalink)
Old 28 Apr 2015, 08:26 am
Send a message via Yahoo to partyd
Do you have a part number for that radio kit ? also is the radio mount into the vehicle ? or to the dash kit bezel ?
thank you
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
  #14 (permalink)
Old 29 Apr 2015, 10:06 pm
xwing777's Avatar
http://www.amazon.com/Chrysler-Navig...ble+din+pt+kit
The kit comes with bracket you mount to the radio than mount to the new dash bezel. Then you slide the radio and bezel together back into the dash. Before mounting radio to bezel, you slide the radio into the opening to make sure it fits though. On the wifes 06' i only needed to sand the ribs down that hold the factory radio snug inside the dash opening.
Its hard to explain but when you remove the factory unit you can clearly see those small ribs. The opening holds the radio very well and no weight is on the bezel afterwards
Just installed aftermarket radio TexasPTCruisin Sound and Security Forum 0 16 Mar 2013 09:11 pm
Aftermarket radio install superjew78 Sound and Security Forum 7 02 Aug 2012 09:17 pm
Aftermarket Radio Installation bjagd02 Sound and Security Forum 3 01 May 2011 01:56 pm
aftermarket radio install berk3066 Sound and Security Forum 5 28 Dec 2010 05:07 pm
Aftermarket radio help gmariconda Sound and Security Forum 1 05 Jan 2010 04:01 pm
