Timing Belt Replacement
Like Tree15Likes
  #41 (permalink)
Old 03 Oct 2012, 10:27 am
Default Re: Timing Belt Replacement
Take the bolt out on the top cover and pull back. Doubt you can see much far as condition. If it sat for long period I would. If it was run regular although short runs then no. Like tires if you run them, even though they are old they don't crack. Leave them sit and they drirot. JMHO
  #42 (permalink)
Old 03 Oct 2012, 10:41 am
mikelikestobike's Avatar
I had to replace mine this year - car had just hit 90K miles. Died in an intersection.
'03 Manual non-turbo in Silver w/ Factory flames.
K & N Drop in, Modded airbox, MSD Superconductor wires, Strut bar, blue dots in taillights. Sold 12/13
  #43 (permalink)
Old 03 Oct 2012, 01:42 pm
twress's Avatar
When mine went this summer I was driving 70 on the highway, it didn't do any damage to the motor thank God. 108,000 miles was when mine went and the belt wasn't fun to put on..but i did it myself in a couple of days...also replaced the water pump while it was apart. Some good writeup here for help. Bought all the parts from Rock Auto on line, that's where I found the best deal and the also have some coupon code to make it a little cheaper. I just put in Rock Auto coupon codes on search and some came up...
ROUNDIN UP THE WAGONS 02 LIMITED WOODY, 89 CAPRICE CLASSIC
  #44 (permalink)
Old 08 Oct 2012, 07:30 am
Thanks for the info guys. I'll have time this coming weekend to take a look at her car and see the condition of the belt. I'll probably replace the water pump and tensioners while I have it all apart as well.
  #45 (permalink)
Old 08 Oct 2012, 04:35 pm
Originally Posted by MarkB View Post
I cracked the same connector.
Maybe we can use that to determine if a belt has been changed.
Hey that's interesting, we got ours with 119'000 miles on it and the sellers said the belt was done but they had no paper work. They were good people so we said yes'
While I was looking under the hood...I noticed that the connector for the PCM was cracked! Guess the work it was done!
  #46 (permalink)
Old 09 Oct 2012, 03:53 am
  #47 (permalink)
Old 10 Oct 2012, 12:18 am
PTJunkie's Avatar
What does the connection to the PCM have to do with the timing belt change?
Anyone have a picture of it?
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
  #48 (permalink)
Old 28 Oct 2012, 03:47 pm
Looks like the connector gets cracked when the engine is jacked to get to the repair area.
So an old thread but still usefull as my son's PT just shut down on the freeway and a peak inside the cover shows a crumpled belt.
Question is can I (probably) do I want to (not really) and will it run if I do when I am done with the repair. This job looks like a real bear with the space limitations.
Big question is what are the chances there is any engine (valve damage) and how can I know before getting into it?
  #49 (permalink)
Old 28 Oct 2012, 04:01 pm
If he was just cruising with traffic chances are highly favorable that Nothing to be concerned about.
  #50 (permalink)
Old 28 Oct 2012, 04:45 pm
Well what I did on our Woo... (DOHC) .We got estimates on it $800 if no damage but..they were saying they could not tell if there was any engine/head damage till they put a belt on and tried to start it!
I thought that's BS and I can do that myself! What I did was go ahead and pull the belt off put a wrench on the bolt on the nose of the intake and the exhaust cam to see if they would turn. My "assumption " was that if the cams turned the valves were fine? Well neither turned, pulled head found 16 bent valves!
Reinstalled head, T belt,water pump, rollers, etc... the next time, 19 miles later, when the belt snapped again did the same test (wrench on nose of cam) I found 8 bent valves! Exhaust side only.
I made a mistake with the tensioner, did not counter the torque when I sit it to 18 ft pounds. I did rotate the engine to check the arrow was where it should be...it wasn't! But I "assumed " it was correct! Yeah uhh no!
Got it right the second time! Yeah the shop would have been cheaper! But it was the principle of the thing!
PT seems to have an automatic tensioner so your not likely to have the same issue.
Timing belt replacement snakepitt1 Tech & Performance Forum 10 18 Dec 2016 12:17 am
Timing Belt Replacement Instructions PTFever Tech & Performance Forum 46 10 Aug 2015 10:33 am
when to change Timing belt ? Ctown General PT Cruiser Discussions 13 18 Aug 2014 05:40 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
Timing belt replacement? mojogator Tech & Performance Forum 3 12 Nov 2003 03:30 pm
