Is There A How To Sticky For This?
Old 21 Mar 2012, 01:00 pm
Default Is There A How To Sticky For This?
Is there a sticky on how to replace the a/c fan for a 2006 base PT? I've looked at the stickies and there are a couple different ones for fans, but I don't know if they are for the right fan? Is the fan that works the a/c different from the radiator fan that keeps the car from overheating? Or is there only one fan?
I had another post about this, but it's buried now, lol. I took the PT to the dealer because of the stumble at idle with A/C on and I thought it was probably the same thing that's happened 2x before.
2008: dealer described it as "fan is not operational at low speed. Nec to replace fan module". No part number for what they replaced.
2010: different dealer, described it as "Needs new fan module as per diagnosis". Part #5179470AA FAN RADIA 7002002
2012: different dealer from 1st two, described as "Coolant Temp Fan Assembly only running intermittently. Recommend replacing Coolant Temp Fan Assembly."
Is what they are describing at the 3rd dealer the same thing as the first two? They make an after-market part for #5179470AA that can be had for less than $100. Is this part and 'Coolant Temp Fan Assembly' the same thing?
Old 21 Mar 2012, 01:28 pm
Default Re: Is There A How To Sticky For This?
i believe all 3 are replacing the same thing, the one and only fan modual
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 21 Mar 2012, 01:39 pm
Oh, ok! I was trying to explain it to my father, who was trying to explain the problem to his mechanic, and they are both saying what I'm telling them isn't making sense. I've been saying it's an a/c fan and that it is a separate thing, while the mechanic is saying it's the radiator fan. Though the car hasn't overheated, or at least we've never noticed it doing that. If we kept the a/c on in idle for an extended period of time, would it then overheat (we keep it off now)?
Also, can I use the directions in this sticky:
http://www.ptcruiserlinks.com/forum/...-01-05-pt.html
for the 2006 model? Is there anything different that has to be done for the 2006?
Old 21 Mar 2012, 03:54 pm
you can get a copy of the FSM (factory Service manual) here somewhere to download for free. It may not be year specific, but i would think 90% of it pertains to all PT years. I need to replace my radiator very soon so i'll be in the same boat as you in removing the fan.
Old 21 Mar 2012, 06:52 pm
mdfrodolives's Avatar
There is only one fan. It cools the radiator and your A/C condensor.
Tim
Old 21 Mar 2012, 07:02 pm
Tim
X2 The fan has 2 speeds.
Old 21 Mar 2012, 07:14 pm
and the turbo fan has a million-bazillion speeds because it's an infinitely variable speed fan. The speed is controlled by the PCM to react to any given set of parameters that the engine supplies.
Jerry
Old 22 Mar 2012, 09:50 pm
Forget about the variable speeds ... you have a base model. Yes, the fan you need is a two-speed.
Tim
Old 22 Mar 2012, 10:02 pm
Tim
The fact that he needed a two speed was already noted and confirmed, thats why my comment started with the word "AND" and contained the word "turbo" at the start. Just an fyi for the turbo guys that weren't aware of that fact. Didn't want them to buy a two-speed fan by mistake. Make sense Tim?
Jerry
Old 22 Mar 2012, 10:06 pm
Okay guys - you're not all on the same page. You have an engine coolant fan, then you have an interior fan. That interior fan moves both heat and AC cooled air. It's also a two-speed fan.
Now it sounds to me like you're speaking about the Air Conditioner fan??? Totally separate! If this is what you're talking about, it has nothing to do with the fan unit at the front of the car.
I guess a better question would be WTF is your problem? lol If you're not getting any air flow inside the car, that's one thing. If the AC unit is not cooling properly, that's something totally else.
Now, if you can't answer those questions I'd go to the first thread in this section and pull down the parts catalog. It has a pretty good drawing of the plumbing for the AC system.
Sticky throttle? Roxx Tech & Performance Forum 2 29 Jun 2011 08:41 pm
Another Sticky quicksilverdon Tech & Performance Forum 3 29 Nov 2006 02:39 pm
Sway bar sticky? turbomangt Tech & Performance Forum 5 26 Feb 2004 09:39 am
