Integrated Power Module (TIPM) 2006 PT Touring Edition 4dr, 2.4L
Old 04 Apr 2012, 07:49 pm
Post Integrated Power Module (TIPM) 2006 PT Touring Edition 4dr, 2.4L
I'm going through an ordeal and ask for some help. Wife's PT cruiser above: front passenger headlamp (lowbeam) inoperative. I took the wheels off, got into the low beam access hole and removed both bulbs. Bought replacement bulb for R/F lowbeam. Installed new bulb, does not work. Checked bulb on L/F headlamp...it worked; so its not a bulb issue. Checked voltage to bulb socket; got 12 v when lamps turned on...Checked ground on socket and confirmed its good with continuity check. So...i've got good headlamp bulp, good socket, 12V and good ground.
Checked "fuses on "TIPM"... they all are ok. Came to this forum as a lurker and read there exists problems with this model year's TIPMs. Sooooo.....I removed the air cleaner, bellows to intake manifold, airflow sensor in bellows, air cleaner box, disconnected neg terminal, pos terminal on battery, removed TIPM mounting bracket and then disconnected all the wiring to see what's going on. Could not see any problems.
Reassembled all parts and checked car, reset clocks, checked OBD, etc.
All electrical components function EXCEPT
1. R/F lowbeam headlamp still not working
2. NOW the power windows do not work, and the front windows are down.
The funny thing is, I've seen a few PT cruisers in my area running around with only one headlamp on. Here are my questions:
1. Do you think this is the TIPM (its 2 circuit boards at right angle)?
2. If yes, (I think it is) do you recommend i buy a used TIPM? What is the estimated cost?
3. If you recommend a new TIPM, any recommended vendors? Dealership markup on parts makes buying one at the local dealership cost prohibitive.
4. Is it true (from lurking on this forum) that i have to go exclusively to a dealership and have the TIPM reprogrammed? Any accurate cost estimates?
I lost my job 4 months ago, so money is an issue to me.
Wife wants to just stay with current TIPM, endure the one headlight and just raise the windows. Can i raise the windows by removing door panel, and supplying 12V to the 2 front windows? Would this work? Any recommendations? How do I remove door panels.
Finally, as a casual observation, the PT cruiser is a nice car for my wife, small, manueverable and has a nice seating posture. But the electrical system certainly seems unnecessarily complex.
Thanks for any help.
Old 04 Apr 2012, 10:22 pm
Default Re: Integrated Power Module (TIPM) 2006 PT Touring Edition 4dr, 2.4L
Do you have a set of test leads?
I have attached a photo of them.
Get to your socket and pin out the socket contacts with the test leads to the bulb.
Have some one help you if needed and use pins if needed to make sure that contact from the socket to the bulb is perfect.
This will test if it's a bulb to socket contact problem.
Just fixed a problem like this in my brother's kid's Honda
Once we determined it was a contact issue I changed the socket and it works like a charm.
I hope this helps
Edit: If you get the light working then we can look at the window problem.
Chrysler has way too many dangling wires on the PT and most often that is the source of electrical problems.
Old 09 Apr 2012, 02:02 pm
Dorman Products offers this TIPM as an R & R option. That might work for you.
Old 31 Mar 2014, 09:07 am
old corps, what did you decide to do? i have the exact same problem with the exact same pt cruiser...my mechanic said I just need to replace the tipm, any idea where to get a deal on one?
Old 31 Mar 2014, 11:40 am
I looked quick and there are some on ebay? There are used ones that are crazy, and I think I saw new ones that are real crazy for price (with exchange).
If i was buying used, I would try and start with a local yard.
I haven't put any time or thought into this post, just a place to look for ideas?
Old 26 Jun 2014, 10:08 am
Talking Re: Integrated Power Module (TIPM) 2006 PT Touring Edition 4dr, 2.4L
Hi all - We have issues with window not rolling up, sun roof and power ports not working. we purchased a Doorman TIPM from Autozone - Before I dig in and try it I wondered if anyone has done them themselves or has a service manual
2006 PT
Old 10 Oct 2014, 03:10 pm
I'm replying to this thread with a question of my own. When I got this PT it had a battery light on occasionally that usually goes out by itself soon after illuminating. When I had the rig checked out by the local Chrysler dealer they couldn't find anything wrong with the charging system or battery but said that a bulletin told them to change the TIPM. I elected not to have them do it, spooked by the nearly $1000 they quoted for the job.
I'm wondering if you guys with more knowledge would advise me to replace this module when I'm not actually having any trouble except for the occasional light?
101Vet
Black 2006 Turbo GT
Bought for OW (Original wife)
But growing on me
Old 10 Oct 2014, 10:41 pm
Did you check your ground wires? Check your ground wires going to the driver's side fender. They are known to have bad connections even if they look good on the outside.
Old 10 Oct 2014, 10:50 pm
Thanks for the tip, good sir! I will check that out tomorrow. Much appreciated.
101Vet
Black 2006 Turbo GT
But growing on me
Old 11 Oct 2014, 09:07 am
Charging wire from alternator (heavy wire) routes to starter with fusable links, make sure it is secured and not rubbing on axle
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Tags
electrical, ipm
2006 PT Cruiser Touring Edition Reynolds1961 Tech & Performance Forum 3 04 Oct 2010 09:31 pm
2006 Touring Edition-Will These Rims Fit? zharrison07 Wheels, Tires, Suspension 4 19 Feb 2010 05:23 pm
2006 PT Cruiser Touring Edition zharrison07 General PT Cruiser Discussions 15 16 Feb 2010 10:16 am
Does 2006 Touring Edition support... EmeraldICE General PT Cruiser Discussions 4 19 May 2008 09:34 am
2006 Touring Edition discovering06 Wheels, Tires, Suspension 3 08 May 2008 05:40 am
