Need help! '05 2.4 non-turbo pt cruiser
Old 23 Jun 2012, 12:45 am
Default Need help! '05 2.4 non-turbo pt cruiser
So my story begins like so..
I was just leaving from my son's doctors appointment when I started the car and put it in reverse it went a few feet and just died! It wouldn't start again, it would turn over but not start. $72 later in towing fees it was dropped off in my drive way. We found a forum that told us how to pull any codes. The code came up P0340, which is the camshaft sensor. I look at how to fix it and get really excited since it is so simple. I pick my part up from a local auto part store and install it. Still the same result! The next day I find that you should change the crankshaft sensor as well so I do that, still nothing! I call a couple family mechanics and they come look at the car and find that my camshafts are stuck. I pay for a rebuild head because my old one was warped (the car never over heated). Everything is put back together and a new timing belt as well. The mechanics go to start the car and still the exact same result! It will turn over but not start! My mechanics are going to tare down the car and see if the timing is off since we have noticed the difficulty so many people have had before us. I guess I am just hoping someone might have an idea of what could be going on? Any information could help! Thank you in advance!
Old 23 Jun 2012, 01:24 am
mdfrodolives's Avatar
Default Re: Need help! '05 2.4 non-turbo pt cruiser
Sounds like your new mechanic put the timing belt in wrong. Was it the same guy who said you had a warped head?
Tim
Old 23 Jun 2012, 01:46 am
It is the same mechanic that said I had a warped head.
I have the head sitting in my front yard, figured I'd keep it as a lawn ornament! The cams were so bad they wouldn't turn when the car first died.
If the timing is off would it still act the same as it did when it originally died? I know the same code is coming up p0340, which I know is the camshaft position sensor.
I did buy an after market sensor not OEM and I have heard that it could make a difference. Not sure if I should just bite the bullet and buy a OEM sensor or let them re-time the car and hope it starts.
Old 23 Jun 2012, 05:34 am
Ray_Dockrey's Avatar
The reason they wouldn't turn when the car died and then wouldn't start is because you broke the timing belt. I am sure there was nothing wrong with the original head.
Old 23 Jun 2012, 07:47 am
I'd get OEM sensors if it were me - the aftermarket one's may be the cause, and don't last, so it's safer.
It MAY be possible that when timing belt broke, valves hit jamming cams, but the cams won't turn without belt when cranking - I assume they tried with head off turning cams by hand?
Old 23 Jun 2012, 11:01 am
If the cams won't turn motor won't turn over unless belt is off. Far as a warped head,if you don't have cam rock it can be milled flat. Has the magnet for the sensor been looked at? If the timing was even close it should at least run if it was a timing issue.
Old 23 Jun 2012, 01:39 pm
The timing belt never broke, it was intact when the car just died. After changing the sensors I did some more looking and found that it could have been the timing that jumped time so went for a new timing belt. While we were taking things apart we found that the cams would not turn until you loosened the cam housing and even then it was most difficult to get them to turn.
After removing the head and taking a nice look at it you could see where oil and air had been pushing through the head gasket. The head was also very warped and looked from a side view, kind of twisted.
My mechanic did state that he had thought he might have got the timing wrong since he has never done a pt cruiser and the Haynes manual we have has a few different ways of timing and none of them state that they are the timing for the '05 model. I did find a forum on here that stated they had to use the '07 timing for their '03 engine. I was just hoping to find someone that knows about the '05 2.4 non-turbo engine and might know the right timing that is needed and if the aftermarket sensors could be a main cause of this mess?
I have owned this car for a year and never had any problems with it until the beginning of this year when I was rear ended and $4300 damage was done to the rear end of my car. Ever since then the gas mileage went to crap and a month or so later I had to fill the engine coolant because it went nearly bone dry and then a month later the same thing happened. All the up keep on this car is done on time.
Old 23 Jun 2012, 01:43 pm
And to answer the question about the magnet. We did look at that and there is no visible signs of damage. We are taking the car back apart again today to see if we can figure out the timing.
Old 23 Jun 2012, 02:39 pm
The accident has nothing to do with anything. Unless someone drove the car and hurt the motor rawhiding it. The fact that you had no coolant in it twice explains the head and the cams. It wont show over heating on the gauge when there is no coolant on the temp sensor. But the head would be extremely hot and you would never know it. If the head was warped as bad as you say the cams wont turn because the journals are no longer in strait line and binding the cams.Put the original sensor back and try that.
Old 23 Jun 2012, 02:56 pm
Thank you! I am glad to have answer to why the head was warped when I did not see it over heating. I think we are still having the problem with the timing. Any idea or suggestions on how it should be done on a '05 2.4 non-turbo? I am hoping to have the old sensor still handy. I will keep you updated on this. Thank you again, it has been a very long wait for my beauty to get back on the road and I am hoping today will be the day she is up and running!
PT Cruiser Turbo fun Bigjoedo General PT Cruiser Discussions 3 09 Feb 2012 07:01 pm
Is my Cruiser turbo? joegosox General PT Cruiser Discussions 15 10 Jul 2011 08:18 pm
Colima Pro Street Shadow Turbo VS PT Cruiser Turbo skylight PT Cruiser Videos 5 31 Dec 2008 03:21 pm
Turbo on non-turbo cruiser 04VanillaCruiser General Turbo Discussions 7 02 Aug 2005 07:59 am
new pt cruiser turbo cesar General Turbo Discussions 8 24 Dec 2003 04:58 pm
