PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/index.php)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/forumdisplay.php?f=10)
-   -   2001 PT Cruiser won't start. No Spark (http://www.ptcruiserlinks.com/forum/showthread.php?t=45291)
oscar_the_grouch 02 Sep 2012 04:41 pm
I have a 2001 PT Cruiser that my father in law gave to my son with a broken timing belt (298,800 miles at the time)
I replaced the timing belt and water pump and it ran great with the exception of a miss at idle. We put 80 miles on the car after timing belt replacement.
Car had an exhaust leak the turned out to be a cracked exhaust manifold. (i attributed the miss the the exhaust leak??) I replaced it with a new manifold,.......now the car will not start,.....it's not getting any spark.
The only electrical unplugged for the manifold job were the two 02 sensors. i have checked for any loose or unplugged electrical connections,...............please help!
CREWZIN 02 Sep 2012 05:03 pm
Re: 2001 PT Cruiser won't start. No Spark
Is there any engine light on?
oscar_the_grouch 02 Sep 2012 05:07 pm
Bear with me,.....this is the first Cruiser i've ever worked on. The engine light comes on steady, then it flashes 11 times, on the eleventh it returnd to steady on.
Engine cranks, but no spark.
I'm reading other threads getting info on retreiving codes.
OK,.....3 codes coming up P 0340,....P 0622,....and P 0320. Now all i have to do is figure out what they mean.
oscar_the_grouch 02 Sep 2012 05:19 pm
OK,.....after talking to my son and checking the car,.......we heated the manifold bolts to get them out. There is a spot on the harness that got hot. I opened it up,.........wires were stuck together but pulled apart easily and none have wire exposed,.....i did however cut 2 green wires w/orange or pink tracers on them. I will have to get in there and splice those wires,....clear the codes and check it again.
oscar_the_grouch 03 Sep 2012 09:07 am
I repaired the wiring harness and now I'm getting 2 codes,
P 1684: Driver 5 line 4.
P 0320:Ignition/distributer engine speed output malfunction.
Can anyone Explain what these mean? I have no idea where to even start looking.
It puts up the p 1684 all the time,......only puts the p 0320 after i crank the motor over
CREWZIN 03 Sep 2012 09:38 am
P0320 is no reference signal from crankshaft position sensor detected during cranking.
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles.
The crankshaft sensor (if you decide to replace it) is located right above the oil filter. Please use only genuine MOPAR replacement sensors as aftermarket sensors (although a little cheaper) have a tendency to not work or fail after a short time.
http://img.photobucket.com/albums/v7...tPosSensor.jpg
oscar_the_grouch 03 Sep 2012 02:18 pm
Ok,....i replaced the crank sensor and still nothing. upon closer inspection i found the plug to the crank sensor had been rewired (spliced) at some point. i lost the wire when it went through the firewall,........but i found a broken wire in the iring harness,.........so i spliced the new one that was there into the broken one in the harness and the car fired right up.
I still have a heavy miss at idle but i will look into that later,......and it is throwing a code for the MAP sensor and when driving it cuts out at 3500 RPMS,.......no big deal,.....i will get to that tomorrow.
I want to Thank You very much for the help. I really do appreciate it.
Rob S.
East Brady,PA
CREWZIN 03 Sep 2012 02:22 pm
Good luck with the rest of it.
pluminator 03 Sep 2012 10:10 pm
Rob S.
East Brady,PA
certainly another lose or non connected wiring if its cutting at 3500. Its supposed to do that in park :-D to prevent over revving, if its doing it while driving the vehicle thinks its in park :-D check all the grounds.
just for giggles heat test the CAT with a laser. If its hotter at the front, than the back, its toast which could also cause the vehicle to cutt out around that RPM. Especially if you had a cracked manifold, that usually only happens with a massive overheat, which could be caused by a Converter :-D
oscar_the_grouch 03 Sep 2012 11:58 pm
I went old school with the cat conv.,......it was pretty clogged up so it now has no internals.........could that be an issue?? I really didn't feel like paying what they wanted for a new converter and figured it would perform a little better opened up.
was i wrong to think this? Could this be causing the problem?
The converter was punched out before the manifold was replaced and was driven about 100 miles that way before i swapped out the manifold and it ran GREAT,......it was just noisy.
Keep in mind that we got this car non running w/ broken timing belt and it sat for almost 3 years in this condition before me got it,..........it has ALOT of miles however it was never abused and recieved regular maintnance from the dealer since new (apparently some half assed service),..........we really don't know much about it because my father in law (original owner) passed away and we don't have the service records.
I'm convinced that the issues are electrical since it ran great with the new timing belt,........and for all these electrical issues to just pop up after a simple exhaust manifold replacement seem a little suspicious to me.
