Code P0700 on 2006 PT Cruiser
  #11 (permalink)
Old 17 Jul 2013, 05:15 pm
Default Re: Code P0700 on 2006 PT Cruiser
Oh, just wanted to tell you that I like the color of your PT. The pearl really does a paint job justice. My moms '08 PT is 'Ocean Blue Pearl'. Beautiful color.
  #12 (permalink)
Old 19 Jul 2013, 05:23 am
spice; It is unlikely that the tranny was totally rebuilt. It takes too much time to remove and replace [and clean and inspect] all the parts. Most shops repair the tranny by replacing the obviously bad parts and new clutch plates and seals. The dealerships only install factory rebuilds [usually]. The torque converters are a weak point in some years. And cannot be inspected for wear or internal contamination.
Your leak might be as only a hose that fell off/loose. Fill with atf+4 only. Also, after you add oil it takes about 5 minutes to get a good reading on the dipstick as the fill tube seems to hold fluid for a while.
I wish you better luck than I had.
Tags
2006 pt cruiser, error code, p0700
P0700 code that lies gmhiggins Tech & Performance Forum 7 04 Apr 2014 02:01 am
code P0700 pt cruiser 20002 javolier Tech & Performance Forum 5 18 Aug 2011 04:23 pm
P0700 code mash35231 Tech & Performance Forum 8 18 Oct 2010 06:01 pm
2001 pt cruiser p0700 code Ginz General PT Cruiser Discussions 8 14 Aug 2010 11:05 am
Beyond the P0700 code Vigilant32 Tech & Performance Forum 3 06 May 2009 04:47 pm
