Hey guys. i have not had any particular test done to confirm i have a blown gasket, however with the research i have done i am leaning more towards that as being my issue causing the overheating. if i have to replace this my shop said around 2500-3000. just want to get opinions if this is fair or not. also if i choose to do the work myself has anyone done this before? how hard is it? how long does it take? just needing to get some ideas of what to expect. thanks guys.
Ok. Thanks lion. I'll ask around for more info at the parts stores. As long as I keep water in it I can still drive it for a while, right? I mean it's not gonna cause further damage if I let it go will it? I just don't have the funds or time to do it myself right now.
At that price you could find a lower mileage motor doo the timing belt, water pump and tensioner and swap it cheaper
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
I know right now it needs about a half gallon a week. I keep a check on it every couple of days. I only use it to drive to work and back. About 10 miles round trip.
UPDATE: Upon the advice of a trusted source I tried something to help with the problem. It seemed to work. At least for a couple of days. Then the smell of burning coolant returned. I the opened the rad cap only to discover there was no pressure in the cooling system. Normally I would ease open the cap and let it hiss the pressure off. This time nothing. I'm close to calling it quits. I hate to get rid of such an underrated machine but I can't keep throwing money at it. Any help would be great guys.
Symptoms: it does not overheat, the coolant gets ran into the overflow tank and out onto the exhaust, the temp does run cool sometimes but under load it goes to normal temp, pretty much the three o'clock position on the gauge. Tried: new thermostat, product to seal leaks. Do not have money for: full diagnostic, head gasket work, too many more parts. |
Was it hot when you removed the cap? Also check the hose to the overflow that the end is tight fitting and there no holes in the hose.
![]() ![]() ![]() ![]() 03 Dream stock___________________________ 04 Touring turbo lite stock_________ 02 Touring stock_____________________ The "Three Amigos" __________________________________________________ __________________________________________________ ___________Performance, Body and Service, OEM This Is my project page. http://www.ptcruiserlinks.com/forum/...oject-1-a.html This is a great read from one of our own! Badglas badglas.blogspot.com Last edited by Busted_PT; 08 Apr 2015 at 07:24 am. |
Yep.
You've got a blown head gasket. The worse part is the coolant in the exhaust. There's a chance this will eventually pit the cylinder walls. Then the engine will possibly smoke and use oil. There may be coolant in the oil pan as well. This can cause scoring of the mains and rob bearings. If you could do the work yourself, you could likely fix the head gasket issue for under $500. And ironically, the hardest part would be the timing belt. Once that's out of the way, removal of the head is pretty straight forward. Once removed, the head is taken to a machine shop to be tested and rebuilt. The deck with be machined flat if slightly warped and the valves ground and reseated. Then it's just a matter of putting it all back together. $3000 seems extremely high at a shop. I figure somewhere around $1,000 to $1,500 would be the right price where I live. But for a $2500 PT Cruiser, you would still have to do some soul searching before spending that much. The cheapest answer would likely be a replacement engine from a salvage car. That's what a used car dealer would do to fix it. They'd just buy one of the extremely plentiful PT salvage engines for around $200 and have it installed for around $500. You might consider that too. ![]()
![]() Last edited by Handy_Cruiser; 08 Apr 2015 at 07:30 am. |
Thread Tools | |
Display Modes | |
2.4L Head Gasket Replacement | lmarkie74 | Tech & Performance Forum | 12 | 13 May 2014 08:21 pm |
head gasket replacement w/turbo | goodwrench67 | Tech & Performance Forum | 4 | 17 Feb 2014 08:23 am |
Hot Motor after head gasket replacement | dtrott | Tech & Performance Forum | 73 | 08 Sep 2012 05:20 pm |
06 Head Gasket Replacement | laynemoore | Tech & Performance Forum | 3 | 01 Jul 2012 02:26 pm |
head gasket replacement and cam/crank relearn | jhnhardee | PT Cruiser Convertible Forum | 0 | 18 May 2011 09:02 am |
