Car Won't Star Start After Tuneup
Like Tree3Likes
  #21 (permalink)
Old 20 Oct 2016, 09:27 pm
Default Re: Car Won't Star Start After Tuneup
Originally Posted by Fk5 View Post
Why are you replacing the camshaft position sensor? I do not think that your symptoms indicate that is a problem. Even if you are throwing parts at it, that is probably a $50 mistake. Steve said it *could* be the crankshaft position sensor. Why not do a little diagnostic work instead of running to the parts store? If you insist on buying something, why not go for a scan tool?
*FWIW, general consensus seems to be that the Mopar cam position sensor is superior. (4out5boardmembersagree) I went aftermarket because the dealer was closed and no trouble so far <knockwood>
Sorry that's what I meant I was writing that on the bus. I haven't bought anything I was just wanting to get more information. Haven't had a chance to had a chance to take the wiring off and rescan yet but I'm off work for the next day so I'm going to do everything I can.
I haven't bought anything I was just trying to get some general information and I have a OBDII scanner at my disposal.
Originally Posted by ptcruisersteve View Post
I am not positive of the color wires you have going to your coil so please verify that the colors I am posting is correct. From what I have the dark green/orange is your ASD positive wire. dark blue/tan wire is one of the coil's ground triggered by the PCM and the black/grey wire is the other coil's ground trigger by the PCM.
Check to see if your ASD positive dark green/orange wire has voltage on it.
Voltmeters at Harbor Freight are reasonable at $5.99.
Digital Multimeter - Save on this 7 Function Digital Multimeter
How are you resetting your engine trouble codes?
Yes those wires are correct. I will test it out tomorrow and report back.
I am resetting the codes with the scanner, is that right?
Fk5 likes this.
  #22 (permalink)
Old 20 Oct 2016, 10:38 pm
Yes, you need to reset the DTC's with the scan tool. Which scan tool do you have?
  #23 (permalink)
Old 21 Oct 2016, 07:55 am
Fk5 Fk5 is offline
I get it. I post on here all the time while locked up in here trying to figure out what to do with my car. Then I go in the garage with the FSM and reality may or may not be the same. The bad thing is when try to relate what I did to my car and forget certain things, like what I exactly torqued bolts to. Of course with my Harbor Freight torque wrench it is only an estimation anyway!
2003 GT 5 speed
162,000 miles
  #24 (permalink)
Old 21 Oct 2016, 04:16 pm
Okay so here's the latest update:
Reset the codes using Autel AutoLink AL519
Tried Starting
Check engine light comes on red light goes off
Took the wiring off camshaft position sensor got error code: P0340
Disconnected ignition coil and using the multimeter on at ohms:
6.32 green orange w/ blue and orange
8.86 green orange w/ black and grey
  #25 (permalink)
Old 24 Oct 2016, 11:01 am
Any ideas guys?
  #26 (permalink)
Old 25 Oct 2016, 08:44 am
Why is your car overheating? You shouldn't be having that problem.
Now you basically have to look for the spark from the plugs to the pcm signals. Start at the PCM signal to the coil and look for the voltage that activates the coil. If you see that, then go to the coil and make sure the signal is getting to the coil, then check if the voltage comes out of the coil and also check that it gets to the plugs.
Someone will need to help get the schematic (check the service manual post 03 is same as 05 for this system) then check for voltage at each point along the system. Red lead to wire and black on a good ground.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
  #27 (permalink)
Old 25 Oct 2016, 09:39 am
Have you checked the ASD positive dark green/orange wire for voltage with the ignition on?
  #28 (permalink)
Old 26 Oct 2016, 07:42 pm
Thanks for all your help guys, but unfortunately I had to take it to the shop because being without a car was killing me, they got it to start but said they head gasket was blown so at this point I'm just gonna have to junk it.
Thanks again for all of your help!
  #29 (permalink)
Old 26 Oct 2016, 09:42 pm
Thanks for the feedback. Did they say how they got the engine to run?
  #30 (permalink)
Old 27 Oct 2016, 06:44 am
Where are you located? Some other members may want to buy some parts before you junk it. I'm also curious as to how they got it started. I wouldn't take their word for it that it needs all that work, either. BUT, I don't trust other people to work on my stuff and ALWAYS get a second opinion if I can't draw my own conclusions.
Tags
p0031, p0037, wont start
On-Star Mirror chiefsfanforever70 General PT Cruiser Discussions 5 28 Jun 2014 05:21 pm
5 Star Shine? PT-ERA The Detail Shop 6 11 Feb 2007 10:17 pm
Three Pointed Star turbomangt The Detail Shop 9 01 Dec 2004 11:00 pm
