Oil Pressure Sender/Sensor Info
  #11 (permalink)
Old 05 Aug 2022, 01:55 pm
Default Re: Oil Pressure Sender/Sensor Info
I replaced the oil pressure sending unit in my 2003 GT turbo, and it was easy. I looked at my wife's 2007, and found it was not accessible from under the car. there are extra frame members, and oil coolers blocking access. You can't even see the sending unit from under the car, and no room for your arms! I will try from above by removing air box and fuse box. The old socket I purchased from the dealer when I bought the sending unit for the GT doesn't fit the 2007 sending unit, so I bought a 1 1/16" deep socket which was perfect.
Oil pressure sender for gauge? GtPt05 Tech & Performance Forum 7 04 Oct 2016 02:12 pm
Oil Pressure Sensor ???? nonstopgo68 Tech & Performance Forum 6 30 Jun 2014 08:43 pm
Tire Pressure Sensor Battery Life Info Ray_Dockrey Tech & Performance Forum 4 09 Nov 2012 07:25 pm
How do I reach the oil pressure sender? wuzadoo Tech & Performance Forum 6 05 Nov 2012 06:06 pm
Fuel Pressure Sender PeTe Turbo Performance 3 01 May 2003 02:26 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
