PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/index.php)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/forumdisplay.php?f=10)
-   -   P0133 and P02096 Engine Codes (http://www.ptcruiserlinks.com/forum/showthread.php?t=67406)
wolfeman461 01 Jan 2021 05:25 pm
Hello fellow PT Cruiser owners! I purchased my 2006 PT brand new and with 240,000 miles on her now she is still running strong! I just had an opportunity to purchase another PT Cruiser recently with 80,000 miles on it. Its a 2005 and it had been setting for quite a while by the previous owner. I got her cleaned up and running good except that I am getting a check engine light with a P0133 and P02096 codes. Could both of these codes be in relationship with one faulty component? It runs and drives just fine but I really would like to figure out how to fix it and take care of the problem? I got fresh gas in it also. Any ideas guys? Any help would be greatly appreciated! Thank You
LionPT 01 Jan 2021 07:06 pm
Re: P0133 and P02096 Engine Codes
P0133 Bank 1 Sensor 1
Replace the O2 Sensor at the exhaust manifold (upstream).
ptcruisersteve 01 Jan 2021 07:24 pm
I would suggest removing the triggered engine codes and see if the same codes come back with an OBDII Scanner tool.
P0133 -O2 (B1 S1) Slow Response
Possible Causes:
1. Exhaust leak present in the exhaust manifold or exhaust pipes
2. O2 element is fuel contaminated
3. O2 element is deteriorated or it has failed
P2096 - Downstream Fuel System 1/2 Lean Conditions:
Possible Causes:
1. Exhaust leak
2. Engine mechanical problem
3. O2 Sensor has failed
4. O2 Sensor signal circuit or return circuit problem
5. Fuel contamination
Your 02 sensor might be triggering P2096.
I would suggest checking for exhaust leaks first then check the wires going to the 02 sensor.
If okay I would check for engine mechanical problems. You might have something causing the 02 sensor to trigger.
Do you have a turbo on your 2005 Pt Cruiser? If so they are known to have cracked exhaust manifolds.
