Multi Function Switch
  • 1 Post By ptprice
Old 03 May 2021, 04:43 pm
Macgyverman1123's Avatar
Default Multi Function Switch
Hey Y'all!
So, I think I need a new multifunction switch. I was on the way to work this morning when I noticed tiny little whisps of smoke coming from the hole that the turn signal stalk goes into. They eventually went away, and everything seemed to work totally fine. However, once I eventually got to work I noticed that the fog lights would not turn off. To prevent battery drain, I just pulled the fog light fuse, but when I went to drive home, they wouldn't come on again, even after I put the fuse back.
I'm assuming I need a new switch, even though everything else still works. How hard is the steering column disassembly, and do I have to disable the airbag?
-John P.
Go Canes! #TakeWarning
Old 03 May 2021, 08:27 pm
ptprice's Avatar
Default Re: Multi Function Switch
The MFS isn't that difficult to remove. (1) disconnect negative battery terminal. (2)With a long shaft Phillips screwdriver remove rear steering cover by accessing the connector screws located in the deep bottom holes in the lower steering cover. (3)There is a snap connection on the cover seam, press to separate the two pieces. (4)Once cover is off, removed two top MFS screws and the (5)screws attaching the washer switch to the MFS. They're separate units. (6)Drop column enough to lift MFS enough to access plug. To remove, push red plug safety bar to open. Remove plug. (7)Lift MFS up and out. (8)Remove flasher unit. (9) Install flasher unit on new MFS. (10) Reverse procedure, install new MFS.
rcktpwrd likes this.
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Tail Lights, 3/8" Belt Trim, 5 piece bumper trim, Leather tilt steering wheel, Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 04 May 2021, 01:33 pm
rcktpwrd's Avatar
Cool Re: Multi Function Switch
switch isn't too hard to remove and replace. Also not hard to repair the little ramp that turns the fogs on/off, but if you saw/smelled smoke might need to replace the assembly...
Joel
www.rcktpwrd.com
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Multi-function switch... but not... jm4n69 General PT Cruiser Discussions 11 12 Oct 2017 04:35 pm
I need this multi-function switch... anyone? Rowdy Classifieds: Want To Buy 12 07 Apr 2017 10:34 pm
Multi-Function Switch sscanlan Tech & Performance Forum 4 19 Aug 2012 02:17 pm
Multi Function Switch missinglink Tech & Performance Forum 7 11 May 2011 07:47 pm
WTB - Multi-Function Switch ucantcme Classifieds: Want To Buy 11 13 Oct 2008 03:03 pm
