A/C Problem - doesn't appear to be low refrigereant
Old 15 Jun 2021, 08:42 pm
Default A/C Problem - doesn't appear to be low refrigereant
We have a 2008 NA Cruiser. Recently the AC compressor has started to cycle on and off fairly often, especially at idle. Purchased a refill kit. We hooked it with the AC running, and initially, it was in the green, then when the compressor kicks on, it goes up into the red. Any idea what might be going on? Thanks!
Old 16 Jun 2021, 01:30 pm
rcktpwrd's Avatar
Cool Re: A/C Problem - doesn't appear to be low refrigereant
Is the cooling fan running when the a/c is turn on?
Joel
www.rcktpwrd.com
Old 21 Jun 2021, 12:51 pm
Default Re: A/C Problem - doesn't appear to be low refrigereant
Hi - Just had a chance to check and the fan does come on when I turn the AC switch on at idle. Another interesting thing was as I was going down the road and turned the AC on, I heard a thunk, maybe one of the air control doors closing hard, I'm not sure.
Old 21 Jun 2021, 05:11 pm
ptprice's Avatar
I had a similar problem with SOOO BIG's A/C in 2016.
The clutch in the A/C compressor pulley was only working intermittently.
Bought a compressor on line for $158.00.
Part #CO 27001C from AC Components LLC.
Still works perfectly. Use it every day, Spring, Summer and Fall
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chromed Side Spears, Grills, Fuel Filler Door, Door Locks, Handles/guards , PRND3-1 Bezel, Tail Lights, 3/8" Belt Trim, 5 piece bumper trim. Cool Vanilla White shift ball, Leather tilt steering wheel, Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry. Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers. Back up Camera, 7" Monitor.
Old 21 Jun 2021, 08:04 pm
Should the pressure shoot up into the red like that when the compressor kicks in?
Old 23 Jun 2021, 02:49 pm
I don't have the equipment to vacuum and redo the system.
Old 23 Jun 2021, 07:09 pm
rcktpwrd's Avatar
Smile Re: A/C Problem - doesn't appear to be low refrigereant
not sure how accurate those ac recharge kits/gauges are... It is easy to overcharge the system with them.
Joel
www.rcktpwrd.com
Old 25 Jun 2021, 02:28 pm
Not sure either, but I haven't added any at this point. The compressor clutch is cycling on and off too quickly at idle though.
When fixing it yourself doesn't go so well Whistler Tech & Performance Forum 13 18 Nov 2013 12:32 pm
Oil Leak-Where it doesn't Ikster Tech & Performance Forum 11 09 Mar 2013 05:55 pm
air conditioner doesn't work... problem with switch kcerica Tech & Performance Forum 4 27 Jul 2011 07:22 am
fan doesn't work but doesn't overheat 4SPEED General Turbo Discussions 3 07 Nov 2009 10:20 am
wife doesn't get it> turbomangt General PT Cruiser Discussions 11 19 Nov 2002 09:24 pm
