My 2003 Touring has a slow coolant leak. I mostly keep it from overheating by making sure coolant is topped off, because I don't want to put any more $ into it. The reservoir plastic is so cloudy I can't see the level even with a flashlight, so I bought a cheap replacement from RockAuto for about $25, inc. shipping. Trouble is, I can't tell what one of the two connectors holding it in place are(one is a nut , other is a ?) and there doesn't appear to be a YouTube, etc. on how to do it.Anyone have diagram/description that would help?
A/C: No a/c 1st time turned on this Spring. Took it to my shop and they diagnosed leaky line. Diagnosis, charging, putting in new line cost over $600. Second time I turned on a/c a couple of weeks later, no a/c. Back to shop. This time a different leak, in the a/c suction and liquid line(Mopar 507 3557 AB). This is the only a/c line I can't find aftermarket and Mopar don't make it no more. My shop was ready to hit the salvage yards. I have no doubt good parts can be had this way, but I told them to forget it. There would probably just be another leak in one of the remaining lines, anyway. Here is the point of this whole a/c story. I called the parts dept. of one of my local Chrysler dealers and the guy was able to check parts inventory of just about any dealer in the country, and one of them had that part in stock (as of a few weeks ago). If you need a 507 3557 AB, call Tillman Motors in Montana(59501) at 406-265-5428 or 406-540-0201. About $250 plus tax and shipping. I would love to grab it but can no longer justify the expenditure. I'll just suffer with windows and sunroof open whenever I need to venture out in the Mid Atlantic summer, which is not often, being retired and still Covid19 wary. |
Be thankful it's not a seized compressor and clutch problem. Fix it $$$$ or you ain't going anywhere.
I've already replaced control arm bushings, motor mounts, radiator hoses/thermostadt, radiator fan, tiny light bulbs for dash displays, ignition switch, headlight control on steering column, hatchback lifters, alternator, starter, transmission, and one a/c line that was leaking, only to find a leak in the dicontinued suction line. Screw the a/c. At least the car runs. Did most of that stuff plus head gasket replacement on black 2001 limited I had before some idiot totaled it. Right now, all I want is to replace coolant reservoir on my crappy replacement silver 2003 touring. Reservoir has two connecting points; there is a nut on the right side but the left side is different and I can't get a good look at it. If I just knew what tool to use I could remove it and replace with new clear one so I can see the coolant level.
Don't recommend it but didn't want to wait, or spend the money. To be honest, didn't know which hose to order. I fixed a high pressure hose. Don't know for sure but wouldn't a low pressure hose be easier?
![]() PS I've never seen the coolant level in my jug. Never cared.. Last edited by circus; 24 Jun 2022 at 11:59 am. |
Thread Tools | |
Display Modes | |
coolant reservoir question | kruzin4now | Tech & Performance Forum | 4 | 16 Jun 2022 07:56 pm |
Coolant Reservoir Cap | LionPT | Classifieds: Want To Buy | 3 | 11 Jun 2014 04:43 pm |
Coolant hose from reservoir | Bansheelos | Tech & Performance Forum | 2 | 03 Nov 2013 03:48 am |
PH level of HOAT Coolant | yaschief | Tech & Performance Forum | 2 | 13 Aug 2008 01:01 pm |
Coolant Fluid Level | Ed Lim | Tech & Performance Forum | 2 | 28 Sep 2003 07:38 pm |
