  #11 (permalink)
Old 18 Jun 2003, 04:22 pm
Send a message via AIM to Exhaust Depot
I have been going crazy trying to find out what the stock injector size is on the srt-4. I found it to be 33lbs! I run 15psi to redline and i am at 90% duty cycle. I have 40lb injectors that I am installing today and will be setting the boost to 18psi up to red line.
As for the BOV not being needed. I respecfully disagree. When I installed my BOV, I noticed quicker recoveries from my turbo as I shifted. The stock surge valve was not big enough to accomidate the extra flow of air from the boost being turned up.
E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip.
  #12 (permalink)
Old 18 Jun 2003, 04:24 pm
Can one fo you guys get the PN off the stock injector? I would like to compare it with mine.
Also, break down and get teh stage 1 kit. its worth it if you ask me.
If you guys want, I can start carring the stage 1 kit and will offer it for less than your dealer?
  #13 (permalink)
Old 18 Jun 2003, 04:30 pm
If we want? For less? Just order them Hector!!!
Click to see my GT!
  #14 (permalink)
Old 18 Jun 2003, 05:01 pm
Send a message via AIM to Steve03GT
\'03 GT Cruiser,White w/ Auto Stick, MOPAR Stg. I, AirAid intake,Alpine XM radio w/ 4 MBQuartz, Autometer Lunar Boost and A/F Gauges
\'02 Corvette (510 RWHP/510 TQ)
Member of 11sec. club &
NRA Benefactor Member
  #15 (permalink)
Old 18 Jun 2003, 05:48 pm
NOW you tell me...[xx(]
I'm always a day late and a dollar short...[:I]
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
  #16 (permalink)
Old 18 Jun 2003, 07:47 pm
Send a message via AIM to tthrift
hey guys i just looked up the part numbers for the injectors
2003 gt cruiser injector # 4852747aa
2004 pt cruiser turbo injector # 4891574ab
2004 gt cruiser turbo injector # 4891574ab
the 2004 injectors are not available yet no depot in chrysler has any in stock
tommy
  #17 (permalink)
Exhaust Depot,
Sounds like a great offer, but I would ask you to wait on making the decision until DC and Mopar start talking to each other and resolve some of the profound questions that have been raised. I believe UniqueTwin is working on this, but no one has heard the results yet. Until then, everyone with even the default warranty would be foolhardy to "do the kit." By the time the warranty has expired, I would fully expect guys like you to come up with even better enhancements. The last thing I would want would be to see you get stuck with these things till we're sure you have a market.
If DC/Mopar do get their fecal matter compacted, add me to your list of customers.
Light almond GT w/5 spd, aluminum gas cover, 400-watt amp w/Kenwood 3-ways in rear, EJECT power button, custom dual exhaust, hidden trailer hitch, mini-flames by Streamline, mini-flames around windshield washer, \"amx\" turbo-up custom intake, Stage 1, BTG strut tower brace, Eibach Pro-Kit Springs, Custom 17x7 wheels.
  #18 (permalink)
Old 19 Jun 2003, 02:19 am
Rocky buddy whats uP!?
I will get them from my local guy so its not I will have to stock them.
As for getting you guys larger injectors or as for you getting the 04 larger injectors I dont think it will do you any good with out an emanage like I have on my car or an apexi afc or a 04 ecu.
Here is why:
Say the injector sprays 1 gal every minute. Lets call this a 1 gal injector. It has a 1 second on time from the ecu.
Now you get a 2 gal injector. It still has a 1 second on time from the ecu. So you can easily see how you will run very rich unless you can reduce the 1 sec down to .5 seconds.
  #19 (permalink)
Old 19 Jun 2003, 09:39 am
injectors have to jive with what the ECU is thinking they are doing?
Homepage:
  #20 (permalink)
Old 19 Jun 2003, 11:24 am
Yoa ED--just suffering through another MT summer (green mountain peaks all around, big trout pulling the unwary visitor into the river, etc). It's a rough life but...
While I don't understand these things the way you guys do, I do recognize that it's a "system" that needs to be upgraded. My understanding was that someone was going to need to crack the codes on the DC PCM before a full upgrade could be made. Is this not correct? Can I bypass the PCM's functions on fuel and boost management?
Thanks for the clarification on the Stage I situation. I'm going to hold and see what UniqueTwin and her colleagues have been able to sort out before making a decision (I have the 7 yr/70K extended warranty, so I'm a little hesitant about discarding that extra-cost item).
Take care, Bro.
