Part Identification
Like Tree5Likes
Closed Thread
  #21 (permalink)
Old 21 Jan 2016, 09:13 am
Default Re: Part Identification
you know I said like...not definitive with the picture I posted.
Having worked on so many vehicles over time I have seen tools, bolts,nails wood screw,watches,wires,hoses,bits and pieces of unknown parts etc. and even a Twinkie drop out from under the vehicle when I have worked on them. There is no guarantee that the fastener you found even belonged to your PT Cruiser.
  #22 (permalink)
Old 21 Jan 2016, 09:24 am
Handy_Cruiser's Avatar
The photo below is my GT turbo engine. But look at the bolt hole in the cylinder head just to the left of the blow off valve (with the blue). If I remember correctly, some NA engines have a stud bolt like yours in that or a nearby hole that is used to secure the steel line that runs along that side of the head. When changing the cam sensor, it may get taken loose so the steel line can be moved. And if not put back, it might have just been hanging there in the bracket on the steel line ready to fall at some point.
Like I said before, there's several bolts like this on or near the PT engine. But at least this is one more place to check.
  #23 (permalink)
True that but with Gottogo's post questioning if it was really the Positive post, I wanted him to be sure (with the sticker poster) that he knew exactly which bolt you were talking about.
rckstein likes this.
  #24 (permalink)
Old 21 Jan 2016, 09:30 am
Originally Posted by Handy_Cruiser View Post
Like I said before, there's several bolts like this *on or near the PT engine. But at least this is one more place to check
Completely clean no oil. How many PT Cruiser's engines are that clean.
Look again at his original post.
Originally Posted by GotToGo View Post
Found this under the PT today. Directly beneath the engine.
Looks like a mounting stud of some kind.
Anybody recognize it?
  #25 (permalink)
Old 21 Jan 2016, 09:38 am
EDITED: No. Too small to be the rear lower strut mount bolt.
PS: That bolt is steel with a tin/zinc plating. You can polish it to look shiny using a wire wheel. And it stays shiny. That means mostly zinc and little or no tin in the mix. It's the same material used in many bolts in many locations on the PT.
  #26 (permalink)
Old 21 Jan 2016, 09:58 am
rckstein's Avatar
It looks very similar to the stud that the grounding wires attach to on the inner driver side fender. He said there was some battery work done recently, perhaps someone took it off to clean the wires and forgot to put it back?
Handy_Cruiser likes this.
  #27 (permalink)
Old 21 Jan 2016, 10:51 am
That's the best guess I've heard so far. I wonder if the OP is getting all this.
  #28 (permalink)
Old 21 Jan 2016, 11:25 am
while this is too small comparing the OPs picture in the first thread there are other similar fasteners on the PT 2.4 engine. But even with my fairly clean engine you can still see some dirt and oil in and around the engine compartment.
The OP's burred picture appears to be a very clean fastener.
  #29 (permalink)
Old 21 Jan 2016, 11:34 am
Enough guessing. Hope the op finds where it came from.
Closed Thread
Head identification help Rochndil General PT Cruiser Discussions 5 19 Dec 2013 01:33 pm
identification kalena The Detail Shop 13 02 Oct 2013 11:57 am
02 Dream Cruiser identification help!! twress General PT Cruiser Discussions 3 17 Jul 2010 11:24 pm
Engine Identification BT7 Tech & Performance Forum 4 13 Sep 2009 10:58 pm
Need help with part identification snittykitty General PT Cruiser Discussions 12 17 Dec 2003 10:50 pm
