Turbo air intake hose cracking
Like Tree25Likes
  #21 (permalink)
Old 11 May 2016, 08:47 am
Default Re: Turbo air intake hose cracking
When using simple mild cleaner if you wipe the hoses and the rag turns black from the rubber then that is the first sign of the rubber breaking down. I did say from the rubber and not dirt or grease. But that can also effect the breakdown of the rubber. Think about when some of you wipe your wiper blades when you wash your car in one sense it is the same thing. Well some of you do that?
IMO most all replacement intake pipes on most vehicles are for looks and the feeling of thinking you get more power then what actually happens. Most OEM intake system were thought out very well.
2step and wingman55 like this.
  #22 (permalink)
Old 11 May 2016, 10:17 am
To be clear about hard pipes , in some application they do have advantages but more so for temperature control and a longer reliability and wear factor over OE parts. If the engine is so modified that the need for larger CFM intake pipe diameter is needed it is the easiest and most practical means.
I am aware of the claims of collapsing hoses and also the thought behind expanding hoses under pressure causing a lazy throttle.
  #23 (permalink)
Old 11 May 2016, 11:01 am
To answer the respose about knowing when it went failed. It pretty much makes a noticeble whine/hissing sound when you take off from a stop. To patch it up until the new one came in, i went with a hard pipe install. (about 40 bucks for everything at the local auto store. The reason i chose to go back to the OEM was clearance and heat concerns. The hard pipe elbo at the turbo end runs pretty close to some coolant hoses and vacume hose for the turbo and man do those hard lines get HOT! All i did was run back in forth to work (15 miles one way at 45 MPH) and noticed some slight melting marks on the coolant hoses. The rubber on the OEM elbo acts as a good insulator for heat and keeps the pipe away from the hoses. Also, the straight part is double walled for less heat transfer. I'd be scared to death the something would catch on fire with plastic elbo and metal hard line kit.
  #24 (permalink)
Old 11 May 2016, 06:43 pm
Originally Posted by Handy_Cruiser View Post
You shouldn't have this going on. Many turbo PT's have well over a 100K miles on them with no deterioration of this air pipe at all. You may want to check your motor mounts to assure the engine isn't rocking too much and pulling on the pipe.
For a replacement, the upper pipe between the turbo and air filter box is fairly easy to find at salvage yards. It's the lower pipes that seem to be hard to find undamaged. Salvage yards like to drag cars around with no wheels on them and/or pick them up with forklifts. Both can damage the lower pipes.
You can also find plenty of aftermarket pipes, especially the upper one. Just search eBay for "PT Cruiser turbo pipe". Many examples will come up. Some of these are universal but can be cut to fit. You can also get an aftermarket cold air intake that goes all the way to the turbo. I believe K&N and several other companies make ones like this. Here's a link to some on eBay.
pt cruiser k&N intake | eBay
You hit the nail on the head. Car has been "idling rough" ever since I bought it knew. Just checked all the passenger side mounts and they are ugly. Turns out the rough idle was in fact engine vibration. You would have thought the dealer would have found it on the 3 separate times u brought it in complaining about it feeling like it was gonna stall and vibrating at stop lights or at my 5 year lifetime warrenty inspection. Guess I will see how much I'm gonna have to fight to get them replaced under warrenty.
  #25 (permalink)
Old 11 May 2016, 11:57 pm
dougs's Avatar
I have a 2008 turbo lite; all the hoses and tubes and wires still look shiny and new at 75,000 miles. Original motor mounts with their famous soft rubber had to be replaced at 45,000 miles, under the extended warranty...
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
  #26 (permalink)
Old 12 May 2016, 11:08 am
wingman55's Avatar
YIKES!!! You guys are scaring me here. I just bought an '04 with the standard turbo. When I looked at it, I didn't REALLY LOOK at it. I know that it was suggested to check these things, but I am guilty of not quite knowing what to look for.
So, anyway, when I did my first oil change the other night, it just so happens that I DID look at the big fat tube that runs right by the oil filter. It's got some rusty spots, but it's quite solid. I did NOT check the rubber ends though.
I guess I should crawl under and check 'em since it's literally going to be a Grandma's car (my wife will be transporting her mother in it).
dougs and Handy_Cruiser like this.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
  #27 (permalink)
Old 03 Mar 2017, 03:45 am
_PTGT03's Avatar
Jut wantef to clarify. The hose is really becoming brittle and cracking at the clamp location on the turbo end. Either my turbo is running hot or these are just crappy hoses/material.
i saw this photo on a amazon.com review for the same part !
myckee likes this.
  #28 (permalink)
Old 03 Mar 2017, 11:10 am
Looks like the one the OP bought on Amazon says Mopar in the title, but is coming from China with a non-Chrysler part number. So its not too surprising, I guess, that the knockoff part isn't using the same quality materials as the original. That is not always the case, but in this instance it appears to be true.
I wonder if you could use a silicone aftermarket elbow and clamp it on to the hard pipe. You could probably drill a hole in the hard part for the vacuum line too. That way you wouldn't have to buy another new crappy "oem" part.
  #29 (permalink)
Old 03 Mar 2017, 04:00 pm
_PTGT03's Avatar
i just ordered the part from the dealer and ... will report if the elbow is the softer rubber. but a 2 year exchange warranty from defects makes it worthwhile
Turbo Coolant hose? Replacement/Hose Size PTTuber Tech & Performance Forum 9 07 Aug 2015 05:27 pm
Air Intake Hose..... Pati_M General Turbo Discussions 4 02 Aug 2012 06:33 pm
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
03 GT Intake hose and lower box with AirRaid Quick Intake Pt_SRT Classifieds: For Sale/Trade 2 16 Feb 2010 06:36 am
BTG Turbo intake--Blue hose nbr10 General Turbo Discussions 0 08 Aug 2003 11:47 pm
