RUNNING SUPER ROUGH!!
Like Tree6Likes
Old 20 Sep 2022, 05:05 pm
rockandroller's Avatar
Question RUNNING SUPER ROUGH!!
I just got the car back from the bodyshop - the body guy said "this car is sure running rough".
It was running fine when I brought it in, but its been sitting around there ( waiting in line) for a couple of weeks now.
I noticed the battery was on the low side the weeks before I brought it in ( was planning to put the battery on conditioner when I got back - but it is three or four years old - at least! - so maybe time for a new one). Anyway voltage is normal charging voltage when the car is running.
BUT not sure whats up with this rough idle! No trouble codes registered, but I get a "pending" 0700 ( also saw that a month ago, when the car was running fine - I notice 7xx-codes seem to correspond with low battery voltage in the past, new battery making them disappear.
Never seen the super rough-running before though! Any hints??
Also, when looking up 700 code, found this odd TCM "reset" sequence ( never heard of it for PT before)
Fully press your foot on the gas pedal until it reaches the floor. Leave it pressed for 10-15 seconds until you hear a click. This will activate your kick-down switch. Wait for 2-5 minutes before interacting with your vehicle this includes opening doors, connecting a mobile device, or pressing anything!
Anyone ever done that reset?
2004 'Turbo Lite'
Old 21 Sep 2022, 06:14 am
Default Re: RUNNING SUPER ROUGH!!
Possibly bad gas? You did mention that it was sitting for a couple of weeks.
When was the last time you did a tune up (spark plugs and wires)?
I have never heard of the reset you mention.
2003 Electric Blue Touring Edition (Sold Nov. '10)
2003 Bright Metallic Silver GT Wagon (Sold Apr. '11)
2004 Black GT Wagon (Current)
Old 21 Sep 2022, 12:55 pm
Question Re: RUNNING SUPER ROUGH!!
Hmm, a little digging around indicates 'vacuum leak' could be a likely culprit... can anybody suggest the most common places to check for vacuum leaks? I haven't cracked the manual for this car in more than five years...
this is 2004 Touring ( "turbo lite")
2004 'Turbo Lite'
Old 21 Sep 2022, 02:21 pm
Exclamation Re: RUNNING SUPER ROUGH!!
wow, it really SHAKES! I popped the hood open to poke around and see that it shakes NOTICEABLY. It looks like a blown hemi chugging away there. I cleared the P700 code and it hasnt come back. Battery voltage when its not running is 12.5V (seems low to me)
maybe battery is unrelated to this problem, but I had noticed it hard starting last month whihc I put down to the older battery getting weak.
This "shaking" has just come out of the blue, though - it was running great before I dropped it off at the bodyshop. Has an almost full tank of gas, but I would not say its "old" gas - though gas quality in this little town is probably questionable ( we only have one gas station and its not a 'name brand'...)
2004 'Turbo Lite'
Old 21 Sep 2022, 05:59 pm
_PTGT03's Avatar
shaking is likely reflective of a uneven cylinder balance, likely caused by a simple misfire...
it'd start troubleshooting to determine if there's any ignition or fueling / compression problems
not an intermittent issue, it's consistent which makes finding the problem easier.
or bring it to a professional for a diagnostic
Old 21 Sep 2022, 08:39 pm
soonercruiser's Avatar
"Just sitting around for weeks"....gas was my first thought too.
Was the tank full when you dropped it off at the body shop?
Someone could have driven it a bit, and put some bad gas in after they felt guilty.
Otherwise, what PTGT said.
Check all your spark plug wire connections too.
Frank, aka SOONERCRUISER,
Old 21 Sep 2022, 11:00 pm
Smile Re: RUNNING SUPER ROUGH!!
Thanks for the tips! It was pretty much a full tank a couple weeks ago. I guess that I should have recorded the mileage before I dropped it at the bodyshop... Just seems odd that if its a misfire that there are no misfire codes. Then again it would have to be REALLY bad gas... I have never had a hint of shake like that before! Off to the dealership in the morning tomorrow...
2004 'Turbo Lite'
Old 22 Sep 2022, 12:13 pm
_PTGT03's Avatar
the engine computer is not modern enough to have a high enough resolution to determine misfires that aren't completely obvious, and sometimes other issues can cause rough running but may not be related to cylinder misfiring.
rockandroller likes this.
Old 23 Sep 2022, 06:20 am
I just got the car back from the bodyshop - the body guy said "this car is sure running rough". It was running fine when I brought it in,
Was there any welding done?
Old 23 Sep 2022, 10:45 pm
Post Re: RUNNING SUPER ROUGH!!
I think there was a little welding done around the rockers, yes... Also, I noticed that the (aftermarket) radio is offline ( won't power up). I have had that radio go 'dead' before, turns out it needs to be completely disconnected from battery power before it will reboot again.
Anyway I fiddled around a few minutes looking for any obvious loose wires or hoses and didnt find any - so off to the dealership it went. Unfortunately they said it will be a week or two before they can get around to working on it...
2004 'Turbo Lite'
Tags
p0700, rough, tcm reset
Engine running super fumey (smelling unburnt gas) brian2002utd General PT Cruiser Discussions 7 19 Feb 2018 12:46 am
Car idles super rough FlyinPurplePeopleEater Tech & Performance Forum 4 15 Aug 2015 09:48 pm
Running rough, sometimes... primostoy General PT Cruiser Discussions 10 16 Jul 2012 03:52 pm
Rough running '06 GT CruzinGT General Turbo Discussions 14 21 Nov 2010 08:45 pm
01 PT Running Rough lucky594 Tech & Performance Forum 5 17 Aug 2007 11:22 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
