PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/index.php)
-   Turbo Wheels/Suspension/Handling (http://www.ptcruiserlinks.com/forum/forumdisplay.php?f=19)
-   -   sound not gone... (http://www.ptcruiserlinks.com/forum/showthread.php?t=28985)
superpug666 09 May 2010 04:50 pm
sound not gone...
hi guys just wandering about tricks for checking if my half shafts are still good? i hear a kinda knocking sound (really sounds like a worn out bearing, but both front bearing are new) and at highway speeds the steering vibrates alot.....suspenssion wise im all stock, and i have 225-45-17 tires.... thnaks a lot!!!
CREWZIN 09 May 2010 05:11 pm
Re: sound not gone...
Not sure of any "tricks" but if you can get under the car, grab the shafts and see if there's any play in either shaft. There shouldn't be hardly any. Check the boots on each end of each shaft too (#3, 6, 10 and 13 in the second picture). Look for a cut or tare that might let dirt get into the spider gears.
http://img.photobucket.com/albums/v7...os/CVJoint.jpg
http://img.photobucket.com/albums/v7...HALFSHAFTS.jpg
superpug666 09 May 2010 07:36 pm
it might sound stupid, but is there a special way to check for play? i mean left/ right....frint to back...up and down....because i know its normal that theres a bit of play when you rotate it......
CREWZIN 09 May 2010 08:11 pm
Is there a special way? Not that I know of. As I said, there shouldn't be hardly any play at all, just like on the wheel bearings. Grab hold and push up, down side to side, it should hardly move what-so-ever.
superpug666 09 May 2010 08:30 pm
thanks..once again, CREWZIN to the rescue!!!
CREWZIN 09 May 2010 08:40 pm
Na, I'm just here all the time "monitoring". Almost anyone else could help you out if they can beat me to the forum. :D
superpug666 12 May 2010 05:04 pm
i dont think they can be as quick as you lol...do you know if its a hard work to change them yourself?
CREWZIN 12 May 2010 07:31 pm
I've never tackled a job like that myself. so I really can't say what, if any, kind of specialized tools or expertise is needed.
superpug666 30 May 2010 07:58 pm
ok...im awaiting money to repair it we're quite sure its the half shafts.....
Cal Cruzer 31 May 2010 11:28 am
Give us an idea of your mechanical ability and your tools. It really is not a hard job but you need the tools. Most specifially a 22mm socket (I think it's 22mm anyhow, I would need to check) and you need a torque wrench or torque multiplier that will get you up to 180#'s of torque to put the axle nut back on. You might need a 3 jaw puller if the axle splines are stuck at the steering knuckle. Other than that pretty basic hand tools, floor jack is useful along with jack stands etc
