abs/trac warning light
Old 30 Jan 2011, 03:59 pm
rustyred's Avatar
Default abs/trac warning light
We have a 2001 PT Cruiser displaying a abs/trac light and Handbrake light.The Cruiser has been parked up for around 6 months.Brakes have been serviced and having checked the abs ring found that the N/S front ring was cracked. Took hub off and replaced the ring, but the abs/trac light is still on.Have cleaned all the sensors and checked other rings they are OK.Disconnected battery for a while and reconnected light still on. Also checked brake fliud level and thats ok too.
Any other suggestions or ideas please?
Old 30 Jan 2011, 04:21 pm
Default Re: abs/trac warning light
A search of the forum would give you a couple of threads to read about your problem:
http://www.ptcruiserlinks.com/forum/...ight-dash.html
http://www.ptcruiserlinks.com/forum/...ng-lights.html
http://www.ptcruiserlinks.com/forum/...rac-light.html
http://www.ptcruiserlinks.com/forum/...ntrol-abs.html
Old 30 Jan 2011, 04:47 pm
rustyred's Avatar
Thankyou CREWZIN, will do that.
Rustyred
trac control & abs light staying on in dash bobs turbo pt General PT Cruiser Discussions 13 22 Apr 2017 08:44 am
Intermittent oil warning light pt2 sawdust123 General Turbo Discussions 25 03 Apr 2017 07:41 am
Airbag warning light worldwideboy Tech & Performance Forum 6 18 Feb 2015 08:12 pm
abs trac light donny General PT Cruiser Discussions 1 01 Jun 2010 08:33 am
Issue with my 01 Limited PT - ABS and TRAC OFF light on pasikobri General PT Cruiser Discussions 2 21 May 2010 07:24 am
