Rattle from the rear
  #11 (permalink)
Old 04 May 2013, 10:15 am
2step's Avatar
Default Re: Rattle from the rear
The rotor disk can be somewhat loose with the wheel removed but it should also be a snug fit at the center of the hub. With the wheel mounted and the lug nuts tight, there should be no slop or movement of the wheel or rotor disk when you rock them with the wheel up in the air on the jack. Do you notice any difference with the emergency/parking brake engaged or not? Is the parking brake cable pulling tight like it should when the handle inside is raised?
It may be a good idea to take the car to a local brake shop for a check. Those guys have seen every possible problem more than once.
strangle rattle from the rear end area? superbert1971 Tech & Performance Forum 4 12 Mar 2009 02:57 pm
Driver Side Rear rattle or squeek Imdaddog PT Cruiser Convertible Forum 1 28 Nov 2007 01:06 pm
rear windows rattle gonzomania General PT Cruiser Discussions 6 06 Dec 2004 03:03 pm
Rear seat belt rattle turbomangt General PT Cruiser Discussions 0 06 Oct 2003 09:57 am
Rattle in rear interior compartment! gtobey General PT Cruiser Discussions 6 30 Oct 2002 10:10 am
