Front End Noise on Bumps
  #11 (permalink)
Old 25 Jul 2013, 07:34 am
Default Re: Front End Noise on Bumps
Thanks I understand now why the end links wouldn't come out till I held what I thought was a washer!
The bushings do have threads in them, and I'll take a closer look at that washer/nut in a bit.
I have never seen a setup like that before, the clunking did go away when I put a nut on it? Could be I tightened down everything when I put the nut on?
I though there was play in the sway bar (you could move it up and down) before
I put the nut on it? I guess that nut/washer could have been backing off?
So to bring it back on point...see if you can pull on the end of the sway bar and see if it moves?
Odd Front end noise. pluminator Wheels, Tires, Suspension 3 12 Dec 2012 03:30 pm
front end noise wcerqua General PT Cruiser Discussions 1 05 Jun 2012 08:23 pm
front end noise Luvour04ptgt Wheels, Tires, Suspension 2 29 Sep 2010 07:45 pm
FRONT END NOISE??? help mjb457 Tech & Performance Forum 3 13 Mar 2010 12:41 pm
My front end sqeaks when I go over bumps lilooetruiser Wheels, Tires, Suspension 2 02 Dec 2009 07:23 pm
