Camber bolt kits
Old 21 Nov 2013, 12:35 am
Chriscokid's Avatar
Default Camber bolt kits
Hey guys, need to buy camber bolt kit and not sure which one. After lowering my 05 gt turbo, the alignment has not been right after two alignments. Today the tech showed me that we're still about .8 degrees out on left front. (Not sure why I wasn't told earlier, lol) but anyway I see several that fit pts but most are single offset and larger variance ones are dual offset. A little advice is appreciated
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Old 21 Nov 2013, 07:37 am
Default Re: Camber bolt kits
Where are you seeing that there's different kinds? I bought my "kit" off ebay and there are loads of them all fitting every PT Cruiser. I just picked one with low price, fast shipping and the seller had good feedback. There was no problem with the shop using them. Just type in "pt cruiser camber kit" on eBay.
Old 21 Nov 2013, 08:44 am
Chriscokid's Avatar
This one Had the largest Adjustment it was found at rock auto RAYBESTOS Part # 6161049
Professional Grade
Front; 14mm Bolts; Double Offset; Plus or Minus 2-1/2 Degree
$12.99
I wanted to get one that would surely have enough adjustment but I did not know what the double offset meant.
2006 Honda Aquatrax
Old 21 Nov 2013, 08:50 am
I don't know either. Sounds like the "kit" at RockAuto has you covered and I've always depended on their parts and at $12.99 you can't go wrong especially if it says it would cover the amount of camber your off.
Old 21 Nov 2013, 02:40 pm
CREWZING already addressed it. If that kit goes to 2.5 which is a little unusual that's pretty cool but running that much camber on the street might cause the outside tires to ware more?
I run 1 degree neg camber on the streets without issue. I think 1.75 is the limit for street use without undue tire ware?
I'd have it set to 1 deg neg camber and call it a day.
Old 21 Nov 2013, 11:57 pm
Chriscokid's Avatar
Thanks guys, gettin them ordered
2006 Honda Aquatrax
$400 for camber bolt install?????? gwairbrush Wheels, Tires, Suspension 3 15 Jun 2013 10:58 pm
WTB - 06506379AA - Engine mount bolt (frame though bolt) wheelgarage Classifieds: Want To Buy 5 04 Dec 2011 10:31 pm
Suspension question(Camber Bolt) calangas1 Wheels, Tires, Suspension 7 25 Oct 2011 09:59 am
Which bolt is the tensioner bolt on the alternator? bjagd02 General PT Cruiser Discussions 6 23 May 2010 10:57 pm
CAMBER ADJUSTER KITS GALVANIZEDYANKEE Tech & Performance Forum 6 12 Dec 2008 07:47 pm
