Why no rear swaybar?
Like Tree5Likes
Old 04 Dec 2013, 09:52 pm
Gru's Avatar
Gru Gru is offline
Default Why no rear swaybar?
It's my understanding that Chrysler had swaybars installed on the rear of cruisers for the first couple years or so and then they stopped for some reason. Does anyone know for sure why.
I am thinking that with the rear swaybar, when the cruiser is pushed near the limit, the back end will slide out and come around very suddenly and unexpectedly. I had that happen to me and I found one other story with someone experiencing the same thing online.
So if this is not the reason, why else would they not even have them on the GTs?
In case I don't see you...
Good afternoon, Good evening, and Good night.
Old 04 Dec 2013, 10:03 pm
Default Re: Why no rear swaybar?
They did it to save money.
I added a rear sway bar to mine, and it helped in handling corners.
Old 04 Dec 2013, 10:04 pm
Money, is the big thing. Look at the savings over the production run of the pt. It wasn't seen as a handling car anyway.
Old 04 Dec 2013, 10:22 pm
Ray_Dockrey's Avatar
I found one in a junkyard in OKC for $25 with all hardware. Installed in my 09 with no issues. Made a difference.
Old 04 Dec 2013, 11:17 pm
InfernoGT's Avatar
It's not just the sway bars that were eliminated. Chrysler did a lot of cost cutting especially on cruisers and neons. Here's what I can remember since I have owned both vehicles:
Cut after 2002:
Cruiser:
Sway Bar
Heated Mirrors
Some interior lighting
Neon:
Sway Bar
Chrome Fuel/Injector Rail
Injector Cover
I'm probably missing a ton of little things but those are the most noticeable. Unfortunately, Chrysler never bothered to return any of those cut features once they were back on their feet.
I love hearing that chrysler said that the sway bar was built into the rear axle on the PT's. So what was their excuse for the Neon when they took out the sway bars?
2006 PTGT with 5spd. ~60k miles
Old 05 Dec 2013, 12:27 am
randyincctx's Avatar
Cool Re: Why no rear swaybar?
Cut after 2002:
Cruiser:
Sway Bar
Heated Mirrors
Neon:
Sway Bar
Injector Cover
Engine vanity cover,passenger door key cylinder,rear cargo shelf(except a few upscale models),rear drivers side cargo pocket door/cover,are a few more things deleted.
I got lucky,and found my Eibach rear sway bar on here for $150(shipped),I havent slapped it on yet though.
Aka:~KILLER~
Old 05 Dec 2013, 02:00 am
And more:
Inner side seat-pedestal trim, upper edge trim behind glove box, second horn, rubber weather strips on the bottom of all doors.
ptdoityourself.net - PT Cruiser Model Year Changes
Originally Posted by randyincctx View Post
[B][COLOR="Blue"]Engine vanity cover,passenger door key cylinder,rear cargo shelf(except a few upscale models),rear drivers side cargo pocket door/cover,are a few more things deleted.
Old 05 Dec 2013, 03:04 am
No no no
They are integrated away bars, you just can't see them!
Old 05 Dec 2013, 07:33 am
From PT Do-It-Yourself.net ......
All 2001-2002 PT's came equipped with front and rear external sway bars. In late 2002 that changed - new 2003 PT's were being delivered to customers without a rear external sway bar. In some instances the external rear sway bar was noted on the Mulrooney sticker at the dealership, but absent on the PT. Initially, many dealers did not understand why the sway bar was listed on the sticker, but not included on the car. To appease some customers, some dealers installed the rear sway; possibly believing it was a factory oversight. Eventually, DC received enough calls and issued an informational TSB to their dealers.
TSB: 02-004-02
Issue Date: October 28, 2002
Year & Model Affected: 2003 PT Cruiser
Discussion
From the initial launch of the PT Cruiser (2001 model year) all vehicles built for sale in the US and Canada included two devices for roll control at the rear of the vehicle:
1. An internal stabilizer, integrated into the rear twist beam axle and;
2. An external supplemental bar, which was added during product development to achieve, desired vehicle dynamic characteristics.
An engineering change occurred for the 2003 model year that increased the size of the internal stabilizer bar. This new internal bar provides a level of roll control, which equals the performance of the previous combination of internal and external parts. As a result, the external supplemental bar was no longer required, and was dropped from production.
Note - The addition of a supplemental external stabilizer bar on a US or Canadian market 2003 model year PT Cruiser in the absence of other changes will compromise the vehicles rides characteristics, and is not recommended.
Old 05 Dec 2013, 08:06 am
But that internal bar measures the same diameter on the 01.
I think that was to give dealers something to tell the customer and get this under control.
`01 swaybar to `05 Cruiser? slantram Wheels, Tires, Suspension 6 27 Jan 2013 05:43 pm
swaybar help please ZDaytona Wheels, Tires, Suspension 2 31 May 2012 07:35 pm
24mm vs. 26mm Swaybar? thesameguy Tech & Performance Forum 4 22 Jul 2011 01:35 pm
Installed the rear swaybar over the weekend...wow! Cal Cruzer Turbo Wheels/Suspension/Handling 42 15 Aug 2005 04:26 pm
Rear Swaybar parts & mounting help please Cal Cruzer General Turbo Discussions 5 22 Jan 2004 05:24 pm
