Go Back   PT Cruiser Forum > PTCruiserLinks.com > Welcome New PT Cruiser Members
Stopped for a red light.........
Old 07 Mar 2013, 02:31 pm
Default Stopped for a red light.........
.......2003 pt stalled out, so I Crank and cranked and cranked and it never restarted....Im thinking timing belt but Im forced to fix this myself anyone have any ideas for me? Thanks
Old 07 Mar 2013, 02:46 pm
Ray_Dockrey's Avatar
Default Re: Stopped for a red light.........
Pull the camshaft sensor off the end of the head. It is on the drivers side and easy to get too. Then have somebody crank it and look in the hole and see if the magnet is turning. If it is not turning then the belt broke.
Busted_PT likes this.
Old 07 Mar 2013, 04:32 pm
If belt is good can it be that camshaft sensor is gone, its been threatening to go for over a year now and module says it was going?
Old 07 Mar 2013, 04:39 pm
"threatening to go for over a year" ? What are you waiting for, change it!
BTW: What module? The only thing that should say that it's "going" is the fault code...like P0340.
Old 08 Mar 2013, 10:38 am
Yes that was my error.....when the engine started hopping Id shut it down which i think reset and it would run fine......but i would imagine to diagnose the problem I will replace that first while i have it off ill check to see that magnet is spinning to rule out that the timing belt possibility....is there anythjing else it could be such as a fuse or some other possible issue?
Old 08 Mar 2013, 10:48 am
Most things, including a fuse, will set off the engine fault light. Is your ON? If it is, pull the fault codes and let the computer help you find the fault.
Old 08 Mar 2013, 02:37 pm
It had been shown P0340. so I guess that may be the entire issue ill know tnite
Old 08 Mar 2013, 03:26 pm
When you change the Camshaft sensor, do so with a genuine MOPAR sensor. Aftermarket sensor either don't work or if they do will fail shortly after.
Old 10 Mar 2013, 10:24 am
magnet is not turning. belt gone i guess huh......is there any way to view the belt before taking apart the right side of the engine?
Old 10 Mar 2013, 10:34 am
There's a cover for the belt on top of the engine just left of the oil fill cap.
Tags
pt wont start
Check oil light goes on & off when stopped at light Triplecat2002 General Turbo Discussions 12 06 Oct 2013 03:45 pm
Now what? Sputtering stopped mahgninnuc68 Tech & Performance Forum 7 15 Feb 2012 08:13 pm
05 PT just stopped.... brecie Tech & Performance Forum 2 19 Dec 2011 04:08 pm
My 2.4 stopped any suggestions ?? partsguy78 Tech & Performance Forum 2 24 Mar 2008 02:02 pm
Sub Stopped CHROMEDCRUISER Sound and Security Forum 6 10 Feb 2005 04:46 pm
