Go Back   PT Cruiser Forum > PTCruiserLinks.com > Welcome New PT Cruiser Members
Ignition
Like Tree14Likes
Closed Thread
Old 27 Sep 2017, 02:48 pm
Question Ignition
Hello from PA..
I have a 2006 PT Cruiser, and amm experiencing Ignition problems. It doesn't want to start, when I turn the key. I keep trying, and it will finally turn over and start. I'm scared of getting stuck, somewhere, and it won't start for mem
Is there an Emergency way, to bypass the ignition, if it fails to start for me.
Please help me out,due to financial products, I cannot replace right now.
Bypass ignition ( emergency )??
Old 27 Sep 2017, 03:04 pm
Handy_Cruiser's Avatar
Default Re: Ign
Welcome to the forum from the great sovereign state of Arkansas!
Is your check engine light on? And if so, have you read the trouble codes? Those codes can tell us a lot. An OBDII code reader is best for this. But if you don't have one, you can use the "Key Dance" method in this link:
http://www.ptcruiserlinks.com/forum/...nce-video.html
And if you are interested in getting a code reader, here's some links on inexpensive models that will do enough for most folks:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.walmart.com/ip/OxGord-OB...&wl13=&veh=sem
https://www.harborfreight.com/can-ob...ool-62119.html
podo2000 and Tvio like this.
Old 27 Sep 2017, 03:16 pm
Default Re: Ign
When you say "won't start" do you mean it won't turn-over or the starter engagaes and motor turns-over but will not start? If it won't turn over, I'd do as handy suggested and see if you got any codes through the key dance and make note of them, then I'd give the battery cables/posts a good look over and clean if you see visible corrossion.
Handy_Cruiser likes this.
Old 27 Sep 2017, 04:43 pm
VsandFords's Avatar
Default Re: Ign
Welcome to the forum from Texas.
Old 27 Sep 2017, 05:00 pm
Default Re: Ign
I would suggest a battery load test to make sure your charging system is okay.
Old 27 Sep 2017, 05:34 pm
Question Re: Ign
Hello again,
It was put under a load test, and came up 79%, while starting it. It's charging properly, and, it all checked out fine.
It gave me alot of trouble today,starting, and is getting worse.
Any way, I can bypass the ignition from under the hood, to start it, with the key turned on?
Old 27 Sep 2017, 05:54 pm
_PTGT03's Avatar
Default Re: Ign
Originally Posted by Tvio View Post
Hello again,
I suggest start with reading what the other posts have been in your thread. If you can't help yourself, we can't help you. Have a nice day
Old 27 Sep 2017, 06:39 pm
rckstein's Avatar
Default Re: Ign
Sorry to sound skeptical, but a new member asking how to bypass the ignition, I think any advice should be cautiously given
Old 27 Sep 2017, 06:40 pm
Cool Re: Ign
You know IGN,
I had asked ONE simple Question, and NOBODY, seems to be able to Answer it!!
I got to help myself?
So, Why are You answering to my Postsm
I thought You may know me thing about PT's !
I guess I was WRONG..I can Help myself Very Well, I assure You.
I don't need to hear a sarcastic remark from You, Bud!
Go read up on Your Mechanicical Expertise. .lol
Old 27 Sep 2017, 07:24 pm
rckstein's Avatar
Default Re: Ign
You know IGN,
Sorry if you're offended, but the PT has certain security features built into it to prevent exactly what you are trying to do.
Nobody on this forum knows you, or your intentions.
Closed Thread
